Old 1/14/08, 12:29 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Service drop question
The mast seems to have the required 18 inches but anyone know off hand how much clearence from the roof the conductors should have.
It is only about two inches.
Old 1/14/08, 12:41 AM
tdietrich1's Avatar
Default Re: Service drop question
Off topic question, was the seal broken on the meter base?
tom
Old 1/14/08, 12:56 AM
relliott's Avatar
No but why do you ask?
Old 1/14/08, 2:26 AM
Ted Allen Ted Allen is offline
Originally Posted by relliott
Attachment 17468
That should be called out... The Service provider will fix it at no charge.
Ooops, 18 inches to 24 inches. I always look at it as a safety thing regardless of the clearence, and in this case it looks to me as something the Utillity would fix.
Old 1/14/08, 2:30 AM
The Tie is supported under the drip or Gutter, this always makes me wright it up as a hazard.
Old 1/14/08, 2:35 AM
I have been reading some of MY posts and I can tell you all that I DID NOT POST 90 % of them in the last 6 months or so. However, that is besides the case. I know who did post some of that and strangly enough it was not much different than I would have posted myself. Strange folks strange land..
I wish you all well.
Old 1/14/08, 8:27 AM
Mike Whitt's Avatar
Unmoderated Guest
Strange, I got a PM this morning stating that I had violated someones private account here. I wouldn't know how to do this but it does seem that that person intends to see me in person.
Old 1/14/08, 8:52 AM
Angry Re: Service drop question
Mike:
See this message and then look near the bottom where you call someone a drunkard
http://www.nachi.org/forum/showpost....3&postcount=67
When that link is accessed it takes the member to their control panel, did you do this, if you did better ask Danny to give you some KY Jelly, I am bull s h i t and the showdown will come soon for you and probably the other stooge!
Old 1/14/08, 9:17 AM
Mike Whitt's Avatar
Unmoderated Guest
Originally Posted by jtedesco1
Mike:
Okay I see what you are saying now. I was trying to open up to my Latest Reputation Received so that every one could see the vuglar language that someone had posted there directed toward me. No harm no foul.
Old 1/14/08, 10:33 AM
relliott's Avatar
Thanks for all the great answers.
Old 1/14/08, 10:39 AM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is online now
Not sure about your masthead clearance question but I hope you pointed out that fence to your buyers.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 1/14/08, 10:41 AM
relliott's Avatar
Not concerned about the masthead, but rather clearance of the lines from the gutter.
What is the rule from the NEC?
Wish Paul was feeling better.
Old 1/14/08, 12:36 PM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
For that type of service drop the best infomation will be from the POCO they have pretty spefic detals on the service drop connection and where to mounted to the sturcture or on mast.
As far i am looking at the photo if this place is above the second story or second floor hightwise it should be ok but i wish there is other photo seeing at diffrent angle but the hevey angle iron bracket if lagged bolted or thru bolted to the actual stucture it is ok but on the sheeting [ plywood or OSB etc ] not a really pratical idea becasue few POCO did stated a warning especally with semilong run the line tenstion can be pretty hard on the bracket [ keep in your mind this true with snow/ ice belt area ]
and let me add the last comment here if it is above the window and away from window there is no issue with that.
but again please check with your POCO for most recent regulations for your area.
Merci, Marc
Old 1/14/08, 1:43 PM
relliott's Avatar
Just to restate ,I am mainly concerned with the two hot s touching the gutter if they sag.
Old 1/14/08, 2:14 PM
Here you go! Looks like that connection was temporary, or iy may have been a job with no permit?
Service disconnect question wsiegel Electrical Inspections 3 8/28/07 10:59 AM
Service Drop Was Finally Removed! jtedesco1 Electrical Inspections 1 12/1/06 3:40 AM
Electrical Inspection with Temp. Service? dandersen Electrical Inspections 16 6/27/06 11:41 PM
