Does this look ok to anyone
Not me.
Of course not!
Put some caulking on it no one will ever know .
Roy Cooke Just funnin you . Good catch Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
No way!
jrivera is a non-member guest and is in no way affiliated with InterNACHI or its members.
LIft the pipe up a little.
Mic |
Nothing duct tape won't fix.
tom |
That must be one of those expansion fittings I keep hearing about
Looks like it never got properly seated in the adapter. If it was really glued in there something else would have broken. |
My client was concern I saw no problem but he wanted me to put it in the report.
When you see the pipe pulled apart like that, there is a bigger issue almost always afoot.
When the ground settles and pulls the conduit apart like that, is also tightly stretches the conductors. Meter bases have almost zero room for slack, so the conductors will be stretched up like a banjo string. They can and do bend the lugs in the meter base toward the center...toward the grounded neutral. About 25% of the time the correction to this problem not only involves installing a proper expansion fitting but it often involves replacing the meter can or the meter can interior components due to the stresses places on them by the tight conductors. |
| Service entrance and a raised garden | tjansson | Electrical Inspections | 18 | 9/7/07 8:47 AM |
| Service Entrance | jcampbell | Electrical Inspections | 9 | 10/30/06 12:14 AM |
| Another Service Entrance Amps Question | pdickerson | Electrical Inspections | 2 | 8/7/06 3:39 PM |
| Service Entrance Amps? | dtaylor | Electrical Inspections | 12 | 8/5/06 3:38 PM |
| Service Entrance Amperage? | jfunderburk | Electrical Inspections | 18 | 6/16/06 10:16 PM |
