Nothing confuses me more than trying to determine amperage when no main breaker exists. Can somone please help with the following?
1) What are the service entrance wire sizes (CU and AL) with their appropriate amperage capacities? 2) How do you determine conductor wire size when you can't read it on the conductor? I did a 24 year old house yesterday--what would you say the amperage is based on the photo of the conductor feeding into the panel (photo of panel and service entrance conductor sheathing attached)? (I could not read the rating of the panel itself--hidden behind wires.) Thanks for the help. ![]() “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Many electrical supply companies have a plastic gauge for this purpose...
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
1/0 al can carry 100 to 125 amps so I would assume 100 amp service.
I know assume means make an *** of you and me. Larry |
Are you sure Jae? I've been looking for one for a long, long time and have yet to find one. Please let me know where to get one. I've been told that you can't measure the outside diameter of the insulation to determine the gauge, i.e. you must measure the wire itself. That would be difficult even with a plastic gauge I think.
This is for the service entrance or MAIN FEEDER to the home, not sub panels
from 310.15(B)(6) I give up, it won't let you type a table Last edited by Greg Fretwell; 6/16/06 at 2:26 PM.. |
Roy Cooke sr . RHI. Royshomeinspection.com. CAHPI-ON |
I ordered a guage yesterday from Professional Equipment (item E835): $13.95. But I obviously didn't have one during this inspection. Some of you guys seem to be able to "eyeball it" but I certainly can't.
Would some Guru please post the wire sizes in CU and AL and the appropriate amperage? I'll buy you a beer for doing so.
Also, does anyone make a special comment when the service is only 100 amps? I have been doing so (telling them to talk to a sparkie about the limitations of a 100 amp service). Wondering if that is what most do?
here's one:
And another:
I owe you Larry. Thanks so much.
What is "THW", "THWN", & "TW" insulation? Anyone? “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
There is meaning in the letter sequences used to identify conductor types, and these letters usually refer to properties of the conductor's insulating layer(s). Some of these letters symbolize individual properties of the wire while others are simply abbreviations. For example, the letter "T" by itself means "thermoplastic" as an insulation material, as in "TW" or "THHN." However, the three-letter combination "MTW" is an abbreviation for Machine Tool Wire, a type of wire whose insulation is made to be flexible for use in machines experiencing significant motion or vibration. INSULATION MATERIAL =================== C = Cotton FEP = Fluorinated Ethylene Propylene MI = Mineral (magnesium oxide) PFA = Perfluoroalkoxy R = Rubber (sometimes Neoprene) S = Silicone "rubber" SA = Silicone-asbestos T = Thermoplastic TA = Thermoplastic-asbestos TFE = Polytetrafluoroethylene ("Teflon") X = Cross-linked synthetic polymer Z = Modified ethylene tetrafluoroethylene HEAT RATING =========== H = 75 degrees Celsius HH = 90 degrees Celsius OUTER COVERING ("JACKET") ========================= N = Nylon SPECIAL SERVICE CONDITIONS ========================== U = Underground W = Wet -2 = 90 degrees Celsius and wet Therefore, a "THWN" conductor has Thermoplastic insulation, is Heat resistant to 75o Celsius, is rated for Wet conditions, and comes with a Nylon outer jacketing. Letter codes like these are only used for general-purpose wires such as those used in households and businesses. For high-power applications and/or severe service conditions, the complexity of conductor technology defies classification according to a few letter codes. Overhead power line conductors are typically bare metal, suspended from towers by glass, porcelain, or ceramic mounts known as insulators. Even so, the actual construction of the wire to withstand physical forces both static (dead weight) and dynamic (wind) loading can be complex, with multiple layers and different types of metals wound together to form a single conductor. Large, underground power conductors are sometimes insulated by paper, then enclosed in a steel pipe filled with pressurized nitrogen or oil to prevent water intrusion. Such conductors require support equipment to maintain fluid pressure throughout the pipe. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
You wowed me, Michael. Thanks a lot!
Attachment 4132 Last edited by mboyett; 4/9/09 at 10:38 PM.. |
| Rating Service Amperage | scosta | Electrical Inspections | 3 | 9/25/07 11:50 PM |
| Service entrance and a raised garden | tjansson | Electrical Inspections | 18 | 9/7/07 9:47 AM |
| Service Entrance | jcampbell | Electrical Inspections | 9 | 10/30/06 1:14 AM |
| Another Service Entrance Amps Question | pdickerson | Electrical Inspections | 2 | 8/7/06 4:39 PM |
| Service Entrance Amps? | dtaylor | Electrical Inspections | 12 | 8/5/06 4:38 PM |
