Old 6/7/07, 1:18 PM
Eric Hyde Eric Hyde is offline
Default Service Entrance Question
Ok, this is the 3rd time this week that I've seen a setup like this. The neutral feed is turned into a ground feed and pushed through the mass head. In the panel, of course, there is no neutral feed to be found and all the neutral circuit wires are connected at the same lug where the neutral feed should be. Is anyone else familiar with this sort of setup and help me understand why its not a good idea (assuming it's not)?
Thanks ahead of time!
service-entrance-question-gunther6-013.jpg   service-entrance-question-gunther6-034.jpg
Old 6/7/07, 5:07 PM
Jeffrey R. Pope's Avatar
Default Re: Service Entrance Question
The service neutral is the "ground."
All equipment grounding conductors, neutrals (grounded conductors) and the grounding electrode are bonded to the service neutral at the service equipment.
Past the point of the service equipment, the neutrals and grounds are separated.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/7/07, 5:54 PM
Thanks for the response. So, it sounds like this is an acceptable setup. But just to be clear - the neutral feed can be converted into a grounding cable before the mass head and connected where a standard neutral feed wire should be in the panel?
Old 6/7/07, 6:58 PM
I'm not sure what constitutes a "conversion" in your mind, but the conductor is the same, regardless of what you're calling it.
It is the service-neutral from the transformer to the service equipment. The service-neutral acts as the grounded conductor and grounding conductor for the service equipment.
Maybe I'm not stating it well (cuz I ain't no sparkie ), but I'm sure one of our experts will be along shortly to sort this out for you. However, from what I can see, this is a normal set-up. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/7/07, 7:40 PM
Marc D. Shunk's Avatar
Banned
Yeah, I'm not really seeing a problem here. What, in particular, concerns you?
"The neutral feed is turned into a ground feed", makes no sense, so you might need to explain that a bit.
Old 6/8/07, 12:37 AM
I'm just at the one year mark as a home inspector and I'm still working on the shop-talk, so I apologize for losing you with the verbiage. I've just never seen the muli-thread neutral feed line changed into a single strand grounding line before. I wasn't sure if they performed the same. Problem solved.
Thanks for the post.
Old 6/8/07, 12:52 AM
That's what was confusing.
A conductor is a conductor is a conductor. Solid does not mean "ground" and multi-strand does not mean "neutral." They are simply different types of conductors.
The conductor (in this case) is the service neutral, which runs from the transformer to the service panel, regardless of whether it's solid or multi-strand or a combination of both.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/8/07, 12:54 PM
What about 310.3?
Old 6/8/07, 2:14 PM
Well that's something else altogether. I've never even considered that, but now it's etched in my mind and I will be on the look-out. . .
310.3 Stranded Conductors.
Where installed in raceways, conductors of size 8 AWG and larger shall be stranded.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Electrical Safety Foundation International Links jtedesco1 Electrical Inspections 5 12/8/07 4:10 PM
Cloth service entrance... wwarner Electrical Inspections 5 4/19/07 12:55 AM
Service panel Question cpetty Electrical Inspections 4 1/24/07 10:36 PM
Service Entrance Amperage? jfunderburk Electrical Inspections 18 6/16/06 11:16 PM
Service entrance conductor jjackson Electrical Inspections 30 1/7/06 6:05 AM
