Old 11/28/06, 9:46 AM
mthomas2 mthomas2 is offline
Default Service Equipment Grounding
Older building, two service equipment panels, seperate meters, what appears to be the GEC is at right of left hand panel, in (new to me) small diamieter "BX" style jacket, other end to water pipe. NO GEC to right hand panel. Panels connected together with what appears to me to be a short lenght of standard rigid conduit. Branch circuits pass between panels en route to conduit. Comments apprecisted on grounding, "bonding" between panels, and circuits rounted through panels.
Old 11/28/06, 11:29 AM
Jeffrey R. Pope's Avatar
Default Re: Service Equipment Grounding
A common grounding electrode is fine - the bond between panels may be okay as well. What I don't see is the bonding strap or screw at the grounding bus bars.
The BX jacket should also be bonded at both ends - to the ground clamp and to the panel.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/29/06, 12:30 AM
Thanks!
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Metal Rigid or PVC Rigid what is code bpotts Electrical Inspections 5 12/4/06 2:40 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
