What would you say about this in a service panel?
Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America) |
Looks like wiring. What exactly are you questioning?
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
I don't see it either. What's the problem?
are You talking about the wire wrapped in black tape?
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Buck,
Where's the issue? |
They only thing I could see is that the romex casing or jacketing is left more than 1/2". Other than that, beats me, Dave.
Come on now Marcel, you wouldn't write that up...now would you?
Off course not, but Paul A. would probably mention it like he has before.
Hell, the guy is asking what is wrong, I don't see anything wrong. I believe it is a code item, but not sure. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I wanted to see if any of you guys would write the long insulation and paper on the wires.
Thanks! I did not write it either. Thanks! again Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
The Code only specifies a 1/4" minimum on the jacket or sheath. It does not specify a maximum.
Now if it were excessive lengths, then I would write it up. |
Thanks, Jim. Many think, as I used to, that longer sheathing than 1/4" or 1/2" is a violation.
What are you writing up about excessive lengths?
I don't use a tape measure, but with the image posted, it is not considered an excessive length in my book.
| 100 amp Service w/new 200 amp panel | mlong | Electrical Inspections | 10 | 2/7/08 3:08 AM |
| Service panel bonding to ground | abolt | Electrical Inspections | 22 | 12/18/07 3:47 PM |
| Electrical Safety Foundation International Links | jtedesco1 | Electrical Inspections | 5 | 12/8/07 4:10 PM |
| Service wire size to breaker panel | sfalvey | Electrical Inspections | 12 | 10/31/06 5:28 PM |
| Zinsco Service Disconnect Panel | pdickerson | Electrical Inspections | 7 | 9/16/06 12:59 PM |
