Old 10/22/10, 8:49 PM
John L. McGrath John L. McGrath is offline
Default Service panel in bathroom
Does anyone know the code date that service panels where not allowed in bathrooms?
Need a home inspection in Indiana? Check out InterNACHI's listing of Indiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/22/10, 9:47 PM
Robert Meier's Avatar
Default Re: Service panel in bathroom
Judging from the photo over-current devices were not permitted long before that bathroom was installed. It first appeared in the 1993 NEC. {240-24(e)}
Old 10/22/10, 9:51 PM
Christopher Currins's Avatar
I believe, an expert may correct me, service panels were permitted in all bathrooms up until the 1993 NEC. All meaning commercial and residential.
I was typing as Robert was posting. The toilet would violate working clearance.
Christopher Currins
Certified, Licensed
Old 10/22/10, 10:02 PM
Actually the prohibition is not only for service panels but for all over-current protection devices (OCPD's) in bathrooms. That would include sub-panels too. This rule only applies to dwelling units and not commercial installations. Here's the 2008 NEC wording:
240.24 Location in or on Premises.
(E) Not Located in Bathrooms. In dwelling units and guest rooms or guest suites of hotels and motels, overcurrent devices, other than supplementary overcurrent protection, shall not be located in bathrooms.
The 1993 NEC wording:
240-24(e) Not Located in Bathrooms. In dwelling units and guest rooms of hotels and motels, branch-circuit overcurrent devices shall not be located in bathrooms as defined in Section 210-8.
Old 10/22/10, 10:07 PM
Thanks Robert
Christopher Currins
Certified, Licensed
Old 10/22/10, 10:14 PM
James H. Bushart's Avatar
What if the jurisdiction in which you are inspecting did not have that particular version of the NEC in effect at the time the bathroom was remodeled? This could have been approved by an AHJ. A city near me is still using the 1999 NEC and probably will for another 10 years.
Instead of dealing with it as a "code violation", consider recommending to your client that the unsafe location of the service panel reveals the possibility of the lack of proper permits and suggest that your client run a permit search.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 10/22/10, 10:19 PM
Is this located in the basement, or original utility room? It looks as if the panel may have been there first and then came the bathroom. I agree with James, if this area requires, recommend permit search.
Christopher Currins
Certified, Licensed
Old 10/22/10, 11:35 PM
Thanks for the info. I believe the bath was added. The original house was built in 1981. The bath appears to be more recent. I also noted the clearance.
Old 10/23/10, 6:33 AM
Eric C. Van De Ven's Avatar
Eric C. Van De Ven Eric C. Van De Ven is offline
The panel appears to be original if the home was built in 1981. It looks like a Murry panel, just guessing.
There was most likely no permit pulled as it violates the work space rule. The electrician would have one foot in the toilet!
This may help you: Working space
Added with edit:
Did you look in the toilet for a date? That may help you to determine which code applies.
This may help you as well: Working space 2
Workspace Origins
Installations built before the 1978 NEC only require a minimum clearance of 2 ft in front of electrical equipment. The 30-in.-wide rule has been used since the 1971 NEC. Headroom clearance has been required since the 1965 NEC.
Old 10/23/10, 6:55 AM
The only "code that applies" is the code that was in effect at the time the bathroom was installed.
Homes built in 2012, according to the IRC, will require a sprinkler system, according to the year the code book required them. Homes built in 2015 that are built in a jurisdiction that is still operating under the 2006 IRC that has no sprinkler system are also being built according to code.
You cannot go by the date the code book first instituted the requirement....but the date the jurisdiction adopted it.
If you do not know when that date was, you simply point out the issue that fails to meet today's building standard and direct your client to do a permit search.
James H. Bushart
314-803-2167
Old 10/23/10, 7:36 AM
Since the OP is in Va: Virginia Building Code
Furthermore, as I stated in another thread, I live in Florida and know when applicable codes took effect. If I am not sure, I found out.
The reason you would look in the toilet for a date is to determine when the addition was done. That code would apply. If you perform work, that work cannot cause a code violation. An example would be if you remodel your kitchen, you can't put the refrigerator in front of the breaker panel.
Citing the code would bolster your request for permits as it would appear, at least one thing was done improperly. It has been my experience that when one thing was done wrong, other hidden things were done wrong as well.
Just saying "check for permits" doesn't really help the Client that much. There could be serious ramifications and costs involved to correct this issue.
Old 10/23/10, 7:50 AM
In neither your scenario or mine does the date the requirement first entering the code book take on any relevance.
James H. Bushart
314-803-2167
Old 10/23/10, 8:10 AM
The date it was adopted has relevance.
The fact that the condition exists and is a violation of the current code (2005 NEC for VA), makes it a safety hazard right now, as the electric code is a safety code.
The OP wanted to know the year the code for not allowing panels in bathrooms was introduced. That code may not be relevant. The workspace code would be.
All it would take would be a phone call to the building department to confirm what code was in effect when the home was built.
If the date in the toilet was 2001, then now two codes have been violated, assuming that VA is 5 years behind on adopting codes.
If no permit was pulled, then the current code would be applicable, after the AHJ got done assessing fines and requiring that things got opened up to see what was done.
As I said earlier, this could get costly in a hurry and I have seen it many, many times.
Old 10/23/10, 8:25 AM
LOL. Are you saying that it was NOT a safety hazard before somebody added it to a code book? It was "safe" before 1993 to put a service panel in a bathroom...but became "unsafe" in 1993?
It is safe...or it is not. Unsafe things should be called out no matter what date they were entered into a code book. As for compliance with the local codes, clients should do a permit search and determine that on their own.
James H. Bushart
314-803-2167
Old 10/23/10, 9:17 AM
Did I say that? No. What I said or more accurately was implying, was that the individuals who wrote the code determined that it needed to be added, for obvious reasons.
Clients may not know how to do a permit search, and even if they did, if home inspectors have limited knowledge of the code, just how much knowledge do you think the Client has?
Which is why I do them for my Clients, at no charge.
It is and was an unsafe condition prior to 1993. It was added to the code most likely because of interpretation issued regarding the work space rule.
Is it two feet or three feet, six and a half feet in height, drop ceilings or no drop ceiling......"We will make it easier for individuals to understand. No service equipment in the bathrooms".
That removes all doubt.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Both panels look like the Service panel? mthiltgen Electrical Inspections 6 3/4/09 10:09 PM
Electrical Safety Foundation International Links jtedesco1 Electrical Inspections 5 12/8/07 3:10 PM
Zinsco Service Disconnect Panel pdickerson Electrical Inspections 7 9/16/06 11:59 AM
