Does anyone see how this service panel is bonded to ground?
The green screw just beneath the service disconnect. . .
It didn't look green to me, I'm partially color blind.
Thanks Jeffrey. |
Don't look for green screws, unless they stand out ofcouse. Look at the wiring diagram on the side of the panel. It usually has a drawing showing where the box bonding screw is located (if needed).
hth, tom |
Thanks Tom.
| Neutral bus bar failed inspection | Greg Moritz | Electrical Inspections | 18 | 1/19/08 2:53 PM |
| Service panel bonding to ground | abolt | Electrical Inspections | 22 | 12/18/07 3:47 PM |
| Electrical Safety Foundation International Links | jtedesco1 | Electrical Inspections | 5 | 12/8/07 4:10 PM |
