Old 2/4/07, 11:14 AM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Service Panel Critique
I'm assuming the way they attached the pigtail under the neutral lug is not correct???
There's a double tap on the breaker to the left, 3rd from bottom.
Neutrals and grounds mixed and/or double tapped with each other.
A neutral and ground double tapped at neutral lug at top right.
Double pole breaker at top right...white wire should be reidentified.
Abandoned wires at bottom of enclosure.
I've never seen a panel design this poor...at least not newer ones. ( 1997 )
Neutral and ground bars are nearly right behind the breakers...very hard to see everything.
Anyone care to comment???
Old 2/4/07, 11:23 AM
tdietrich1's Avatar
Default Re: Service Panel Critique
I'm old, do you have a larger photo, or a set of closeup photos(top, middle, bottom)?
I've grown lazy, since digital photos are so cheap, and take lots of photos.
tom
But you mentioned enough. Recommend further evaluation by a trained electrician for possible repair/replacement.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Electrical Safety Foundation International Links jtedesco1 Electrical Inspections 5 12/8/07 3:10 PM
Service Panel Quiz? hmcclard Electrical Inspections 5 10/24/07 11:53 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
