I have seen multiple romex cables run through a single clamp on numerous panels. I know some connectors are rated for multiple cables, but not like this. See upper right corner. This panel is good otherwise. Would you call it out? Defect or improve?
Carl Nagy CENTech Property Inspections LLC cnagy@oh.nachi.org Jeromesville, Ohio 44840 419-368-5814 Serving Ashland, Mansfield, Wooster, Akron, Canton and Surrounding Areas Last edited by cnagy; 2/11/10 at 8:23 PM.. |
| Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I wouldn't lose any sleep over this. No I would not call this out.
No more than 2-3 wires should be bundled together, so this would simply be noted... but I wouldn't recommend having an Electrician correct.
| Cables through sub panel | bsmith | Electrical Inspections | 11 | 3/9/09 5:59 PM |
| Electric Panel | dmozzillo | Electrical Inspections | 26 | 1/26/09 1:18 PM |
| Where is it written.... | bgromicko | General Inspection Discussion | 21 | 1/19/08 9:02 PM |
| Service Panel Quiz? | hmcclard | Electrical Inspections | 5 | 10/24/07 11:53 PM |
