Old 8/11/06, 12:14 PM
Michael Bazzo, CMI Michael Bazzo, CMI is offline
Default Service Panel Used As Junction Box
Attachment 5027Inspected a home yesterday that had a new addition added to the back, the old service panel is being used as a junction box as a new service was installed in the addition. This is a new one on me and not sure if this can be done or not, what do you think?
Great Lakes Home & Property Inspections
Utica MI 48317
http://www.greatlakesinspections.com
Old 8/11/06, 12:21 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
Default Re: Service Panel Used As Junction Box
I have seen it done in the past as well. Before I did home inspections. I saw it in a home over in Hazel Park, MI.
I don't know the rules about this but would like to know what others think.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 8/11/06, 12:27 PM
Jeffrey R. Pope's Avatar
So long as it's covered, it's not a problem. Was there a hinged cover in addition to the dead front?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/11/06, 12:31 PM
Unmoderated Guest
It is done quite often by DIYers and often suggested to them for some reason.
I don't care for this practice AT ALL and do not know why it is done so often.
To me it reeks of DIY, but if covered properly and not overloaded there is nothing illegal or unsafe about it.
Yes a hinged cover was attached to the dead front. Not sure how well the dead front even with a loosly latched cover would contain a fire with out breakers helping to seal the can.
Utica MI 48317
Old 8/11/06, 12:36 PM
I don't like the looks of it either and certainly a dyi er at work. All those wire nuts made me alittle nervous as well. thought crimped connections would have been a better option.
Utica MI 48317
Old 8/11/06, 12:55 PM
James H. Bushart's Avatar
Is there not a general provision in the code that prohibits the use of equipment for anything other than its designed purpose?
Old 8/11/06, 1:10 PM
Unmoderated Guest
I would not say that at all. A correct wire nut plice is as sound as anything else.
Crimping is the stuff of larger service conductors and stranded low-voltage wiring.
Old 8/11/06, 1:14 PM
Yes, there is, and there is some contention as to whether or not splices and wire nuts are allowed in a panel board. It really comes down to the interpretation by the AHJ.
Typically, the conductors for the new service equipment are spliced at the existing panel (which is gutted) to the circuits. This is done by licensed EC's quite commonly.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/11/06, 1:18 PM
bkelly1's Avatar
bkelly1 bkelly1 is offline
Please Note: bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
It is alright here, and in Commercial applications I liked to install, and use terminal strips. They look so much better
Old 8/11/06, 1:45 PM
Peter Foxe Smothers's Avatar
Peter Foxe Smothers Peter Foxe Smothers is offline
It is done by electricians all the time here.
Foxe Smothers ( Owner / Inspector )
Pelican State Inspection
Your Best Choice for Home Inspection in the Shreveport & Bossier City Area!
www.PelicanState.Net
www.ShreveportHomeInspector.net
www.BossierCityHomeInspector.net
foxe@pelicanstate.net
LSBHI #10399
Old 8/11/06, 2:03 PM
Jeff, the panelboard was removed so this is just an enclosure. I have heard of AHJs who want the hinged cover screwed shut tho.
Old 8/11/06, 3:06 PM
I know Greg, I was referencing the post by James where he commented on "listing and labeling." This used to be a "panelboard" enclosure and has been modified into a "junction box," which (technically) goes against its "listing and labeling."
Every time I have seen this condition, the hinged cover has been screwed shut as well.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/11/06, 4:42 PM
It was and still is a "CABINET" and according to its Listing and purpose is not a "JUNCTION BOX" and violates 110.3(B).
If further clarification is needed, the UL site www.ul.com includes a telephone number that can be called to clarify my personal opinion.
The Panelboard was removed from a Cabinet and although a common practice, is legally considered to be a conflict.
2006 UL White Book (large file - 5MB)
See Cabinets
Old 8/11/06, 5:03 PM
Vern Mitchinson's Avatar
Vern Mitchinson Vern Mitchinson is offline
It is quite common here when Old houses that had fuse boxes are up dated to current standards. How ever the old fuse box is removed and a 6 x 6 x 3 metal box with screwed on cover is installed. Licensed Electricians and Electrical Inspectors have approved this so I do not question it.
Usually there are two or more circuits from the new panel connected inside the new box.
I do however wonder about the rule that forbids more then one circuit inside the same junction box.
Vern Mitchinson_CCHI_CMI
Registar
AlbertaNACHI
International Association of Certified Home Inspectors of Canada
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Service Panel Quiz? hmcclard Electrical Inspections 5 10/24/07 11:53 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
Zinsco Service Disconnect Panel pdickerson Electrical Inspections 7 9/16/06 11:59 AM
