Old 4/4/08, 10:00 AM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default Service point on roof
This service point rests directly on the roof. I can't find any reg against this, but it doesn't seem right. Any thoughts?
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 4/4/08, 10:24 AM
Barry Adair's Avatar
Default Re: Service point on roof
That's just wrong!
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 4/4/08, 10:44 AM
Bill Smith's Avatar
Barry - Thanks for your reply. The drop clearances here on Long Island are atypical in regards to what might be found in other areas. I was more concerned with the service point resting direcly on the roof.
631-434-5200
Old 4/4/08, 10:45 AM
Clearance required
Old 4/4/08, 11:09 AM
Bill Smith's Avatar
Excellent - Thanks Joe
631-434-5200
Old 4/4/08, 11:46 AM
Unmoderated Guest
Barry's graphic only show span clearance. That does NOT apply to drip loops.
Joe's graphic shows the drip loop clearance but the graphic is misleading, the 18" number is an exception to the 36" clearance also for spans.
I cannot find anything prohibiting a drip loop from being lower than 18". A drip loop will ALWAYS be lower than the span itself, so if the span can be 18" then the loop can obviously be lower.
TRUE, this is a poor installation ans should be called out as such, but IMO I can't find anything that makes it "illegal".
Old 4/4/08, 12:26 PM
May be wrong but I was taught, thought I had known, and said,
"No lower than 36" above any roof surfaces."
Reroofing has to be taken into account and any less is just unsafe, imo.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 4/4/08, 12:32 PM
Unmoderated Guest
It is code legal to have the drop 18" off the roof in some instances.
Like I said though, all these clearance codes refer to the "span", not simply "conductors".
Just for reference here is the applicable section of the NEC:
225.19 Clearances from Buildings for Conductors of Not Over 600 Volts, Nominal
(A) Above Roofs
Overhead spans of open conductors and open multiconductor cables shall have a vertical clearance of not less than 2.5 m (8 ft) above the roof surface. The vertical clearance above the roof level shall be maintained for a distance not less than 900 mm (3 ft) in all directions from the edge of the roof.
Exception No. 1: The area above a roof surface subject to pedestrian or vehicular traffic shall have a vertical clearance from the roof surface in accordance with the clearance requirements of 225.18.
Exception No. 2: Where the voltage between conductors does not exceed 300, and the roof has a slope of 100 mm in 300 mm (4 in. in 12 in.) or greater, a reduction in clearance to 900 mm (3 ft) shall be permitted.
Exception No. 3: Where the voltage between conductors does not exceed 300, a reduction in clearance above only the overhanging portion of the roof to not less than 450 mm (18 in.) shall be permitted if (1) not more than 1.8 m (6 ft) of the conductors, 1.2 m (4 ft) horizontally, pass above the roof overhang and (2) they are terminated at a through-the-roof raceway or approved support.
Exception No. 4: The requirement for maintaining the vertical clearance 900 mm (3 ft) from the edge of the roof shall not apply to the final conductor span where the conductors are attached to the side of a building.
Old 4/4/08, 1:12 PM
I'll stick with 36" and let a sparky or code official discredit me.
No dishonor in being wrong for the sake of safer practices.
I know and lived through a nightmare with an inspector that was named in a $25M lawsuit for wrongful death of an electrocuted plumber under a house.
Many notations in his report about feeders on soil, open j-boxes, NO GFCI protection... ...even left a note on the doors for anyone entering the premises...
Beyond code is not a criminal offense...yet...and the subject photo appears to be a tragedy waiting to happen to some poor schmuck trying to earn a living.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 4/4/08, 1:13 PM
I would enforce that as the bottom of the drip loop part of the "span" had to be 18" above the roof. If it was touching the roof (or close) you could also call "physical damage". Swinging in the wind, it wouldn't take long for those shingles to damage tthe insulation.
Old 4/4/08, 1:31 PM
I agree! So much confusion by other code scholars!
Old 4/4/08, 1:35 PM
Andrew MacDonald's Avatar
Andrew MacDonald Andrew MacDonald is offline
I'm with Barry on this one... Just plain WRONG.
Andrew MacDonald
MacDonaldPropertyInspections.com
InsightThermalDiagnostics.com
ITC/FLIR Certified Building Science Thermographer
ITC/FLIR Certified Level 1 Thermographer
Old 4/4/08, 2:31 PM
Carla Horne's Avatar
Carla Horne Carla Horne is offline
based on the size appearance it probably needs to be upgraded anyway.
where does the service entrance go where it is out of the picture on the right?
CJ
Old 4/4/08, 3:38 PM
Unmoderated Guest
Just to note, I DID state:
Originally Posted by Speedy Petey
TRUE, this is a poor installation ans should be called out as such,....
Old 4/4/08, 8:45 PM
Marc D. Shunk's Avatar
Banned
Not really. The word "span" has a well defined definition in the electrical trade. The drip loop is not part of the span.
Unfamiliar newer floor structure -- span too long for engineered joists? fbartlo Structural Inspections 8 2/10/08 12:11 PM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 1:21 AM
Help Determining Reportable Service Size cbarrows Electrical Inspections 8 7/19/06 8:12 PM
Moss growing on roof ecox1 Exterior Inspections 43 1/19/06 10:57 PM
