Old 7/29/10, 8:45 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default Service size
House built in '54. Is this a 60 amp service?? I'm guessing it is. The system was a mess, however, I would like to confirm if this indeed is a 60 amp service. Thanks in advance.
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/29/10, 9:12 AM
David C. Macy's Avatar
Default Re: Service size
Joshua
Do you have a pic of the SEC in the main panel?
Many locals around here allow a 100 amp service on a 60 amp meter base. Not sure about your area but it probably is the same.
Nice job of siding around the meter and service conduit.
Old 7/29/10, 10:04 AM
Originally Posted by dmacy View Post
Joshua
Our area doesn't allow. Is it a 60 amp meter base then?
Old 7/29/10, 10:40 AM
Jeffrey R. Pope's Avatar
It's impossible to give you an accurate answer based on the limited info you have provided.
It looks like a 100 amp base, but that has very little bearing on the actual service capacity.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 7/29/10, 11:07 AM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Taken from the InterNACHI course, a round meter base is 60 amp
Round meter bases: Common from the 1920s up to the 1950s, they were rated for only 60 amps and are still often seen on older properties.
Old 7/29/10, 1:22 PM
A meter base is not a definitive determination of the service capacity. It's simply an indicator.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 7/29/10, 1:59 PM
I agree with Jeff.
I was just at a house doing a pest inspection and this is a typical service around here. Even with the round meter base. 100 amp service.
My house is the same way. It is OK with local jurisdiction and electricians.
ID:	38175   service-size-wdi-72910-004-small-.jpg.jpg
ID:	38176   service-size-wdi-72910-005-small-.jpg.jpg
Old 7/30/10, 9:34 AM
LeRoy D. Holm's Avatar
LeRoy D. Holm LeRoy D. Holm is offline
It looks like a 60 amp service but, make sure you check the service cables that come in here is a picture of an inspection I did an inspection with a home that bragged about upgrading the service to 150 Amps. Sure the panel and breaker were 150 but the service cables were for 60. The electrical was a mess, fuses were just as you started down the steps and were your hand would go if you slipped. And yes they are live.
service-size-warren-058.jpg the
Old 7/30/10, 11:32 AM
Leroy
By chance do you have a close up picture of the SEC of the panel. They look like 100 amps. (I am just guessing as I can not tell from looking at the picture)
Just because it has a round meter base does not mean it is 60 amps. (This topic has been discussed in my area numerous times by qualified professionals and in this area most locals will allow a 100 amp service with the round meter base)
Definetly some old, antiquated electrical pictured
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 293 2/10/08 2:20 AM
Question about Determining Electric Service Size sbelda General Inspection Discussion 2 8/18/07 3:48 PM
How Do I Determine Electrical Svs Size (posted by Judy Thompson) AskNACHI.org AskNACHI.org Inspection Questions Forum 3 8/10/07 5:03 PM
Size of service?? cbuell Electrical Inspections 4 4/14/07 5:50 PM
Adequate service size....oh, and a GFCI question ksherstobetoff Electrical Inspections 13 2/8/07 2:18 PM
