Old 7/25/11, 6:18 AM
James A. Levy's Avatar
James A. Levy James A. Levy is online now
Question Service Weather Heads
This is a 3-4 month old service that was inspected by the AHJ. Are weather heads not required on SEU cable services anymore? Were they ever required? I have been calling this condition out without complaint, but this is the second one I have run into like it.
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/25/11, 9:45 AM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Service Weather Heads
NEC 230.54 still requires a weatherhead or a gooseneck. That goes not look like a gooseneck to me.
Old 7/25/11, 9:54 AM
Greg W. Mathias, CCHI Greg W. Mathias, CCHI is offline
Wink Re: Service Weather Heads
I found this one on a ten year old home. I called the agent and sent her this picture and all she said was " not much wrong there, just needs to be stood up nailed back to the house" I don't think she got it.
Greg Mathias, CCHI
Journeyman Carpenter
Global Property Inspections
Lloydminster, AB. Canada
(780)205-9912
Old 7/25/11, 9:59 AM
They allow these in our area as long as the dead head is through bolted into solid framing. Not sure from the picture if that is the case. I think it is a disaster waiting to happen.
Greg Mathias, CCHI
(780)205-9912
Old 7/25/11, 10:02 AM
This is nothing more than vinyl tape wrapped around the SEU. How can it be bolted without a weather head?
Old 7/25/11, 10:03 AM
Thank you Jim. I was second guessing myself.
Old 7/25/11, 10:11 AM
Unmoderated Guest
I think the dead head mentioned would be the triplex anchor.
Old 7/25/11, 10:12 AM
Yes you are correct. Just another name for them.
Greg Mathias, CCHI
(780)205-9912
Old 7/25/11, 11:34 AM
Robert J. OConnor's Avatar
It's hard to tell from that photo angle, but the SE cable might turn down after the clamp which could be considered a gooseneck, which can be used instead of a weatherhead.
The thing I dont like is how they landed and tapped the bare grounded messenger wire. Looks like just two strands of the wire go to the anchor ... ... instead of the full wire going to the anchor with a tap off that for the SE cable neutral ... see the attached diagram.
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 7/25/11, 5:11 PM
Robert Meier's Avatar
Goosenecks, which are formed with just a bunch of identified tape and are permitted by the NEC. They should look like the one in Bob's diagram. Here's the NEC requirement for the tape:
230.54(B) Service Cable Equipped with Service Head or Gooseneck. Service cables shall be equipped with a service head. The service head shall comply with the requirement for fittings in 314.15.
Exception: Type SE cable shall be permitted to be formed in a gooseneck and taped with a self-sealing weather-resistant thermoplastic
Originally Posted by roconnor View Post
The thing I dont like is how they landed and tapped the bare grounded messenger wire. Looks like just two strands of the wire go to the anchor ... ... instead of the full wire going to the anchor with a tap off that for the SE cable neutral.
Those attachments products are referred to as galvanized steel dead end grips and are added by the POCO to secure the drop to the point of attachment. It is not strands from the grounded conductor.
Old 7/25/11, 6:51 PM
After looking at the image again I can see why they opted for the rather ugly gooseneck over the weatherhead. Weather heads are not designed to be mounted on an angle as would be required by way the SE cable is installed. The top of the weather head would need to be mounted with it's attachment screw on top. That would not have been an easy task given the way that the cable was run.
Old 7/25/11, 7:11 PM
Banned
Haven't heard that term here before. That's what I have been calling the SE cables from the POCO since 1975.
Old 7/25/11, 7:31 PM
Unmoderated Guest
Brian, around here if someone says triplex they would typically be referring to the power company overhead cable.
Someone else mentioned only one or two strands around the anchor. That cable has a steel strand that is used to carry the weight and provide the strength.
Old 7/25/11, 8:14 PM
Banned
That's what I was referring to......just called it "SE cables from the POCO".
Old 7/25/11, 8:23 PM
Banned
Don't like that "gooseneck" method......have never seen one here in 39 years of working around houses and farms. In this picture, with high winds and rain, I see that as an easy entry point for water.
In your areas, are any there special requirements to prevent water that got into into the service conduit from entering the panel? I see a fair amount of corrosion here on the SE terminals/wires from water entry.
Electrical service rating jskrypka Canadian Inspectors 7 1/4/09 6:37 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Service Panel question for board sparkies pbolliger Electrical Inspections 8 5/14/06 9:24 AM
Service entrance conductor jjackson Electrical Inspections 30 1/7/06 5:05 AM
