I inspected a one year old home today and the client stated that they have had a few light switches that they have gotten minor shocks from. These are the bigger flat type of toggle switches. Has anyone else had this type of issue, if so what was the result.
Mike Mike Huppi The HomeTeam Inspection Service 503-530-8306 |
Static Electricity Probably...New House....Carpet....and so on. Generally they should not get a shock from a plastic toggle switch. While it is possible they could from the screws...highly unlikely in a new house.
Advice....tell them to pick up their feet when they walk and stop draggin em... Paul W. Abernathy |
Hard to believe static because the boxes are plastic so the screw would go into plastic and not be grounded.
Doesn't the cover screw go into the yoke of the switch which is grounded?
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
The visible (switchplate) screws go into the metal device strap so would be gounded, assuming the switch has a ground connection as is should. So, I suppose it could be static electricity.
Listen to the Guru,.. it IS static. I just finished a new construction today and shocked myself on every light switch I turned on in carpeted rooms. Its your finger touching the screw that holds the face plate on. Peter Doane Realty Check Inspection Service NACHI ID# 05120681
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
http://www.ashi.org/find/ From your site: You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
How 'bout this? I detected a dimmer switch (in the off position) a couple of weeks ago that was warm to the touch. Temp was near 100F. I wrote it up. Anyone think this is normal? It was one of those new toggle switches with a small slide mechanism on the side of it. Three total in the house. 2 were warm, 1 was not.
#1 search on google for maui home inspectors, ashi #211814. |
Jeff Moore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Mr. Larson,
Mr. Thorman shows up if you look for him by name on the ASHI site. |
Thanks for the feedback on the switches, I still referred an electrician to check it because there were a few hot neutral reverses also, so the electrician is going there anyways. There were only two switches that this was happening so let him check it to be sure.
Tom |
He wrote me today to explain why it didn't before. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Flickering CFL | jallingham | Electrical Inspections | 34 | 12/5/08 2:40 PM |
| Trouble Shooting the Simple Light Bulb | mcyr | Electrical Inspections | 20 | 1/6/08 3:47 AM |
| End of the light bulb as we know it!! | mcyr | General Inspection Discussion | 3 | 12/19/07 3:42 PM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 7:22 PM |
| How many forum members to change a light bulb? | kshepard | Miscellaneous Discussion for Inspectors | 9 | 8/2/06 9:56 AM |
