Old 2/1/08, 10:10 AM
tdietrich1's Avatar
Default Shop lights above a drop ceiling....?
OK, this defies common senses, based on number of ballast fires I've had to respond too. However, I would like something better than "I said so." I found shop lights, the kind you either hang from chains or mount directly to ceiling surfaces, mounted above a drop ceiling. So they are open to smoke, flame, or break florescent light bulbs in the cavity.
Any references how this is not safe?
tom
Old 2/1/08, 11:34 AM
Mike Whitt's Avatar
Unmoderated Guest
Default Re: Shop lights above a drop ceiling....?
Unless the area above the drop ceiling is being used as return air then nothing I know of can stop the installation.
Old 2/1/08, 3:53 PM
If they are not actually hanging by chain (or otherwise spaced off the ceiling) it is a 110.3(B) The ballast depends on air flow over the metal can for cooling.
Old 2/1/08, 8:44 PM
I see that type of setup in commercial office strip malls. It's usually 8 foot 2 lamp fixtures hung from chains or seismic wires over suspended ceilings with diffusers under the fixtures. I don't really see a safety issue, but they are a pain to work on.
Old 2/1/08, 9:41 PM
Bob Elliott's Avatar
nice light panels.
That are made for it.Why get laughed at.
Asbestos ceiling tiles scoslett Interior Inspections 30 10/20/07 2:30 PM
Voltage Drop dmacy Electrical Inspections 51 9/7/07 9:57 AM
outlets and lights question Scott Schultz Electrical Inspections 4 1/27/07 7:59 PM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 4 1/22/07 12:24 PM
