Old 8/8/10, 12:20 AM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
Default Should electric water heaters be elevated 18 inches in a garage for safety.
just had a question if electric water heaters should be elevated above 18 inches in a garage for explosive safety due to a spark if the unit is turned on.
thanks for any help
Mark.
House 2 Home LLC
503-602-1420
HomePros@House2HomeLLC.ORG
Protecting Peace of Mind One House at a Time
IAC2 Certified
IR Certified
A favorite place on Google Maps
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/8/10, 12:44 AM
Bob Elliott's Avatar
Default Re: Should electric water heaters be elevated 18 inches in a garage for safety.
Depends who you ask.
http://www.nachi.org/forum/f22/elect...-heater-50686/
Old 8/8/10, 12:55 AM
Thanks Bob I think the code is stating that any sparking device that is capable of creating a spark in a flammable area is worth commenting about. It may be a worst case senerio but it can happen. A. O. Smith states nothing about its electric water heaters. But Bradford White States that their unit should not be placed in a flammable gas area. To me that means a garage where a gas can or car can leak fumes. I don't want to be called to court because a fire that was caused by a electric water heater caused it.
House 2 Home LLC
503-602-1420
IAC2 Certified
IR Certified
Old 8/8/10, 1:05 AM
Joe Funderburk, CMI's Avatar
Do electric wall outlets, extension cords, refrigerators, freezers or any other electrical devices also need to be elevated 18 inches?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 8/8/10, 1:10 AM
Yes in a garage. HMMMMMMMMMM what does that make you think.
House 2 Home LLC
503-602-1420
IAC2 Certified
IR Certified
Old 8/8/10, 1:34 AM
I think...If you write up an extension cord or un-elevated refrigerator in a garage you're going to be looking for a new job because word will get out that you're crazy.
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/8/10, 7:27 AM
Robert Meier's Avatar
For a dwelling garage the answer is no. The 18" area above the floor is not considered a hazardous (classified) area by the NEC in a residential garage. A commercial repair garage is a different story and would fall under Article 511.
Old 8/8/10, 9:38 PM
So do you write up electric water heaters in a residential garage sitting on the floor of the garage?
Theodore Roosevelt
Joe Funderburk, CMI
Old 8/8/10, 11:06 PM
Chuck Evans's Avatar
I think Robert was responding to your non-water heater related question. Electric water heaters are specifically addressed in the IRC.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 8/8/10, 11:31 PM
Paul Pendley Paul Pendley is offline
But those items are not permanent fixtures.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 8/9/10, 4:48 AM
I was responding to, with reference to the NEC:
And the answer is no since the NEC does not consider the area up to 18" above a dwelling garage floor to be a hazardous (classified) area. Does the IRC say something different?
Old 8/9/10, 9:07 AM
http://www.nachi.org/forum/f22/elect...86/#post652399 and subsequent posts.
As an FYI: Texas inspectors are required to write up electric water heater that are not elevated as deficient. The 18 inch requirement is to the lowest ignition source, not the bottom of the unit.
Houston, TX
Do the electric water heaters require earth quake straps dnasser Plumbing Inspections 3 3/12/10 12:34 PM
attached garage ghelder General Inspection Discussion 5 2/23/10 5:40 PM
flammable vapor ignition resistant dbaucum General Inspection Discussion 35 2/19/08 1:42 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
