The electrical fixture is located in a shower in an area recessed high above the water supply and does not appear it can get wet. The label on the fixture says it is okay for damp locations. I have no problem with that. The label also says to use only "outdoor" lamps. I have no problem with that. My question is are lamps to be protected in case they break in the shower area? Most fixtures I've seen have a lens. What is the purpose of the lens? To prevent moisture? to protect the bulb? both? or other? Thoughts please.
774 Manor Road Staten Island, NY 10314 718-514-3393 |
| Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Others will follow but that is not suitable and needs to be wet rated not damp rated.
Unless outside the tub or over 8 feet up from bottom of tub. |
The fixture was fairly high from inside the shower. I didn't measure it but it was more than 8 feet from where I was standing inside the shower. What do you think about the lamps?
First you need to determine what the location is that the fixture is in. If 's damp then it's fine. If it's wet then it needs the proper lamps. Unless this is a fixture of the type listed in 410.10(D) then it's not required to be 8' about the tub or shower rim.
See:
Great info guys. What about my question about whether or not the lamp needs to be covered (protected) or not. Can the bulb be exposed?
In general the answer is you need a shade as those bulbs get hot and hot glass splashed with cold water would cause immediate fracture however there are always exceptions.
http://www.lampsplus.com/products/Li...im__68393.html Gasket included for shower applications. Takes one 50 watt MR16 bulb (not included). Low voltage creates less heat. |
Re: Light fixtures in showers
(A) Wet and Damp Locations. Luminaires installed in wet or damp locations shall be installed such that water cannot enter or accumulate in wiring compartments, lampholders, or other electrical parts. All luminaires installed in wet locations shall be marked, “Suitable for Wet Locations.” 410.4(D).....Luminaires located in bathtub and shower zone must be listed for damp locations, or listed for wet locations where subject to shower spray. So with above information if the lumunaires is listed, cover or not, it's permissible. Open Alzak Anti-Iridescent trim. UL & CUL listed for damp locations. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
A simple work flow would be to: Determine if the fixture is a type permitted in the specific location. {410.10(D)} Determine whether the location is damp or wet. {Article 100 Definitions} Determine if the fixture is listed for the location in which it's installed. {110.3(B)} |
All cans are rated for damp.
Question was about the bulbs. They are specialty and have a gasket O ring attached. Simple is look inside the fixture housing by pulling out the ring and checking for wet rated. |
410.4(D).....Luminaires located in bathtub and shower zone must be listed for damp locations, or listed for wet locations where subject to shower spray. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
One other thing to note is that this fixture might be out of the tub and shower zone so 410.4(D) wouldn't even apply. John said that it was more than 8' above the shower.
Fixture was definitely out of the "shower zone" as defined in other posts. Was not going to be directly exposed to water, although it could be exposed to moisture or dampness when taking a shower. That said, based on everything posted here I think the installation is fine so long as the proper lamps are used Thanks for all the input guys.
Check inside if not sure as once the bulb is removed you can read bulb types allowed. Many cans use a plastic outer ring that melts if wrong non par spot bulb is used. I have seen it happen. |
| Light Fixture above Jacuzzi w/ Shower Spray Nozzle | thance | Electrical Inspections | 45 | 3/13/08 5:14 PM |
| Light fixture in shower | pdickerson | Electrical Inspections | 18 | 10/18/07 6:34 PM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 7:22 PM |
| Light Fixture above shower | tneumann | Electrical Inspections | 27 | 3/11/06 11:03 AM |
