jbilyk is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've never seen this before. I verified that my sniffer was working correctly. There were some bulbs out in this kitchen, so I wanted to make sure the fixtures were live. As soon as I touched the shroud my sniffer went off. I repeated the test like 10 times.
Anyone???
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Never rely on a tik tracer. When they age a little bit, they start acting goofy. It should have been verified with a 'Wiggy' type of voltmeter. Putting one of the leads on the 'nub' contact within the lampholder and the other lead on the housing of the fixture would have verified if the wire connections were reversed.
The trim is most likely plastic, so I don't think it would have been energized. Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
As Jeff said a more conclusive test is needed to determine whether or not your sniffer is actually showing an energized trim. If the trim is metallic and the fixture wired incorrectly it is possible that the entire unit is energized. I would use a volt meter and an extension cord to more accurately test it.
| No lights | pcavalcante | Electrical Inspections | 7 | 9/8/09 4:14 PM |
| Wiring Up A Set of Motion Sensor Lights | Matt Wilson | Electrical Inspections | 1 | 6/14/09 9:09 PM |
| Lights Flickering while appliances start-up and while running. | Jeff Nunz | Electrical Inspections | 15 | 11/27/07 4:04 PM |
| Fan type and recessed can lights | dmacy | Interior Inspections | 7 | 7/23/07 10:39 PM |
| Recessed Lights | dsmith1 | Electrical Inspections | 10 | 2/5/07 11:19 AM |
