Is there any sure way to determine that this type of wiring, its the set wrapped in cloth, is not aluminum? It appears to be silver coated?
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
I can't tell from the picture, but if it's "coated" it's "tinned copper".
It is not aluminum
Mark is right Very old type which will need to be replaced at some point. The covering cracks easy. |
Do you guys call this out and make an issue out of it. It's connections is solid.
The tinned copper wiring is OK, but its sheathing is a problem. The rubber deteriorates and may eventually expose the conductor. So the fact that the "connections are solid" means nothing.
I don't make an issue of it, I simply recommend replacing it. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I mention that it is older wiring and should be checked further for safety.
Spent years working with the stuff in older buildings and often the covering falls off and crumbles. This can be a hazard.Think knob and tube and how you word that? |
I never see it. (Most of the homes I inspect in this county are less than 40 years old.)
I might say something on the lines of: Noted some of the circuits in the home are older "tinned copper" wiring. While it does not appear to be causing any problems at this time, the insulated covering becomes brittle and crumbles with age, causing a safety concern. This wiring is currently considered obsolete, and you should consider budgeting for re-wiring these circuits in the near future. Caveat... Once again I never see these. So others that do see these more regularly may have a stronger, and more educated opinion. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Thanks to all
Lightened up. look at it now.
The problem(s) discovered in the main electric panel such as
+++++++++++++++ Must be a limit on bullet point stuff. Won't break it right here. Erby Crofutt B4U Close Home Inspections Georgetown, Kentucky KY Lic# HI-2041 www.b4uclose.com http://www.kentuckyradon.com Kentucky Home Inspections Kentucky Home Inspectors NACHI02090301 "LIKE" me on Facebook Kentucky Homeowner Resources @ http://www.kentuckyhomeinspections.com BLOG by Erby, The Central Kentucky Home Inspector Join Active Rain HERE Last edited by ecrofutt; 8/6/08 at 7:48 AM.. |
It's definitely tin coated copper. Report on the defects already noted.
Now this is Aluminum Wiring...
Did you check to see if the recepticales or appliances they were hooked to were rated for aluminum.?
Assuming the panel was of course. |
Breakers are rated for copper and aluminum. I have also raised the issues with the grouned and grounding wires being on the same lug.
