A friend of mine added a circuit with two outlets in his basement. Tied into another circuit, added a junction box, I tested the outlets, they are wired properly. An electrician told him not to end the circuit at the second outlet, but to run it back to the junction box and tie into the other half of the original wire, to make a loop. Whats the logic for this?
| Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Do you have a circuit diagram to show us.
Outlet could be a switch or fixture plus are we talking Line or neutral,ground, 110 or 220 ? Ground and neutral loop back to the box. Just came back because I had forgotten about this site till just now. http://www.thecircuitdetective.com/bkgrd.htm#circuit |
There's no reason that this should be done.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
Unless your description is missing some pertinent information there is not logical reason to do this.
Going further with the comments the circuits run in parallel not series.
The question reminds me of how they wire Christmas lights so one burnt bulb does not effect the rest. |
I was fighting with my scanner, I lost. No diagram. Its a simple 110 run, I saw no reason to loop it, didn't know if there was a code reference or something. Seems like a waste of time and wire.
What will end up happening .... someone will be working on the receptacle and they unhook what they think is the only hot feed. They'll get bit since it's fed from two directions. Not really the best way.
| Simple Chimney Question | sschroetke | Exterior Inspections | 8 | 2/17/10 5:56 AM |
| Probably a really stuip question | Rick Vollmer | Plumbing Inspections | 4 | 5/12/09 7:11 PM |
| What do you think??? | tlower | Electrical Inspections | 20 | 11/11/08 5:08 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 9:24 AM |
