Old 7/7/10, 11:20 PM
Frank L. Bartlo Frank L. Bartlo is offline
Question single circuit wired from one pole of appliance breaker OK?
In today's inspection I came across this: a single 15A circuit wired from one terminal of a dual 15A appliance type circuit breaker. See top right of pic.
This seems like it will work OK, but I just want to make sure.
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/8/10, 12:15 AM
Default Re: single circuit wired from one pole of appliance breaker OK?
It will work and trip accordingly. Just someone lazy was working in the panel that didn't bother replacing the 2-pole with two singles or (even easier) pulling off the handle-tie. It's also probable that if it's a newer install, they thought there was going to be a multi-wire branch circuit and they were hooking it up to the 2-pole breaker.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 7/8/10, 4:56 AM
Robert Meier's Avatar
Jeff
The two pole CB is fine as Jeff stated. Pulling off the handle tie wouldn't help since 2 pole CB's are constructed with an internal trip mechanism.
Old 7/8/10, 11:59 AM
Thanks, Jeff and Robert. They were probably planning on having another circuit sharing the neutral, as I did notice lots of 3-conductor wires with the red wires unconnected. The house was pretty well tricked out with a lot of complicated features ... took longer to inspect per square foot than any house I've ever done that was so well maintained,
Old 7/8/10, 7:47 PM
Jim Port Jim Port is offline
Unmoderated Guest
Frank,
Instead of terminology like this "appliance type circuit breaker." the correct term would be a double or two pole breaker.
An appliance can be supplied from either a single or double pole breaker. It would depend on the voltage as to whether the single or double pole were used.
Old 7/16/10, 10:56 AM
Yeah, I'm more careful with the wording in my reports, and do my best to keep terminology simple so lay people can most easily understand what I'm saying. I didn't even make a mention of this one in my report, not being a functional issue.
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Article 240 : Overcurrent Protection Article pabernathy Electrical Inspections 0 5/23/07 11:40 AM
Can an AFCI offer GFCI protection gbeaumont Electrical Inspections 19 7/6/06 11:45 PM
