Old 5/22/08, 1:36 PM
Steve McIntire's Avatar
Steve McIntire Steve McIntire is offline
Default What size Amps is this panel
Need help with understanding the service Amps for this main panel. It is a XO circuit breaker load center square D. The cover says that it is a 100amp panel. There is a 40 Amp breaker at the top and a 50 amp breaker at the bottom. There are several problems I know about such as: double tapped breakers and undersized double tapped breakers, panel is located at the middle of the home with no disconnect at outside meter, SEC is old/worn and panel is undersized for current household loads.
size-amps-panel-p5220686.jpg   size-amps-panel-p5220687.jpg   size-amps-panel-p5220691.jpg   size-amps-panel-p5220684.jpg   size-amps-panel-p5220672.jpg
Steve McIntire, Inspector
EEinspections.com
Old 5/22/08, 3:40 PM
mnahrgang's Avatar
Default Re: What size Amps is this panel
The round base on the meter implies it is a 60 AMP meter.
The panel states that is is rated at 100 AMP.
There is no main disconnect in the panel.
60 Amp service.
Mark Nahrgang
www.HeyMark.info
Old 5/22/08, 3:41 PM
wsiegel wsiegel is offline
What size wire is the SEC? That will give you the amperage of the box. Probably 60. What is that meter rated for?
Old 5/22/08, 4:03 PM
I have added a few more pics. I agree the outside meter looks like a 60 amp service but the meter is not marked. I have had round meter bases that were 100 Amp service. This is obviously original panel, but would have never met code requirements even in the 60's.
size-amps-panel-p5220683.jpg   size-amps-panel-p5220688.jpg   size-amps-panel-p5220671.jpg
EEinspections.com
Old 5/22/08, 4:33 PM
Unmoderated Guest
The meter rating is totally irrelevant. The rating of the meter pan is relavant, but typically is not accessible.
If that is #4CU, which is does look like, I would call this 100A.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Service wire size to breaker panel sfalvey Electrical Inspections 12 10/31/06 4:28 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
