Old 1/10/06, 9:54 AM
hspinnler's Avatar
hspinnler hspinnler is offline
Please Note: hspinnler is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Smoke Alarm, Hubcap or UFO?
I have not seen this type of device before. They were located on each level of the home outside all the required places for smoke alarms. The red lever on the right side says "Rewind". House is over 20 years old. Early wind-up type smoke alarm?
Old 1/10/06, 10:02 AM
phinsperger's Avatar
Default Re: Smoke Alarm, Hubcap or UFO?
Fire bell
Old 1/10/06, 10:17 AM
hspinnler's Avatar
Man, I feel a bit sheepish. The winder thingy is for the bells hammer. Should this firebell be hooked up to the smoke alarm? Do not typically see firebells in residential homes here.
Old 1/10/06, 10:29 AM
Michael R. Boyett's Avatar
Hank, that does appear to be an older model mechanical heat sensing fire alarm. The bronze center part is likely a wax filled tripping mechanism set to trip at maybe 160-180 degrees or so. Since it is mechanical in nature then there would be no way to interface it with a smoke alarm. I'd describe the device and recommend additional installation of modern, high quality smoke alarms.
Old 1/10/06, 10:38 AM
Doug Edwards's Avatar
Hank,
As stated that is a fire alarm. Purely mechanical. Winds up just like a giant clock spring. That small metal button in the center is made of "Woods metal". It has a very low melting point. Same metal they use on sprinkler systems at the sprayer nozzles in the ceilings. Once it melts there is a tiny wire plunger that pops out in the center then all hell breaks loose. It is the loudest thing I have ever heard and I used to be on Aircraft carriers. I had some in my house many moons ago and one night after a few cool brewskis we (me and some equally stupid friends) decided to test one out, so I popped the metal button off the front. It DOES NOT stop until it is completely run down. Best not to fool with it unless you really like being embarrassed.
Old 1/10/06, 11:05 AM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
I would also suggest an up grade.
Their may be nothing wrong with it (as far as it may work) but everything has a life span.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 1/10/06, 11:26 AM
hspinnler's Avatar
Doug. That story was funny. Our curiousity rarely prevents us from leaving things the heck alone. As far as the home is concerned, they already had celing mount smoke alarms in place and they were functioning. They can probably leave them in place if they would like.
Old 1/10/06, 12:07 PM
Hank,
I hear ya. The brand name I had was I think "Vanguard" and looked very similar to the one in your picture. I never touched one of them again once I got that one wound up again.
Old 1/10/06, 1:44 PM
jcundiff's Avatar
jcundiff jcundiff is offline
Please Note: jcundiff is a non-member guest and is in no way affiliated with InterNACHI or its members.
That is a spring wound, heat sensitive alarm bell.
Old 1/10/06, 2:00 PM
Stephen W. Stanczyk's Avatar
I remember sitting through a home presentation on this fire alarm. That was 20-25 years ago. They were expensive then. Hundreds of dollars for the whole house. We of course said no, the high pressure saleman does the typical and calls his "dispatcher" to say we were choosing to go unprotected. Then the price came down. More pressure and then I booted him.
They looked interesting at the time. I would recommend adding current standard alarms but since they aren't hard wired and don't take batteries, what harm in keeping them? They should just be the back-up.
Stephen Stanczyk
Old 1/11/06, 10:29 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
i'd also recomend an upgrade. based solely on the fact that once it goes off, how do you "reset" it. can you still buy the center "woods metal" to replace it? how do you test it? if it were me, i'd leave it up for conversation, but add some smokes near by.
Old 1/11/06, 10:51 PM
Russell Spriggs's Avatar
Russell Spriggs Russell Spriggs is offline
Memories!
After a stint teaching SCUBA in the Keys, then hard-hat construction diving in Pensacola Bay ('73?), a was needing $ and took a job to (attempt to sell) those things.
It was one of the low points of my career, & didn't last long at all . . .
Russ
Old 5/21/07, 2:01 AM
Doug D. Ryan Doug D. Ryan is offline
Please Note: Doug D. Ryan is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sorry to dig up an old thread, but like Russ, I also sold these. They, IMO are still the best - require no power to operate, guaranteed will work once you pop off the sensor on the front (or it gets too hot and pops itself off)!
I don't get the idea of 'upgrade' when no upgrade can do what this kinda old ugly looking things can do. It'll still work during a nuclear strike. These noisy bastards are the bomb, they will wake up even the heaviest sleeper, and jeez man, when's the last time you did a test on your smoke alarms and it actually woke you or your family up?
These fellas will wake up the Kremlin all the way from Washington DC.
My stint was in like 1978 with this ugly system. It rocks though. Wish I could find at least one for my house now. After multiple lightning strikes here, tons of electronics damage r/r over the years, there is no substitute for a real alarm that will work when nothing else will.
I would definitely sleep better.
PS: like sstanczyk said, keep them... but imo, they wouldn't be the back up, they would be the real reason why I wouldn't have to be concerned about some electronic pos made in china to get zapped and not work when I least expected it.
Old 5/21/07, 5:38 AM
Barry Adair's Avatar
The ones I have hanging in the shop/storage are (L) Vulcan Autosonic Mark 60 (manual wind-up 135°F heat sensor) must be used in conjunction with smoke detectors per labeling and the (R) Vulacn PVR Mark II Smoke Detector (photoelectric 120V no battery back-up)
U.S. Safety & Engineering Corp.
Vulcan Headquarters
2365 El Camino Ave.
Sacto, CA 95821
A blast from the past!
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 7/9/07, 9:52 PM
Bill Leavell Bill Leavell is offline
Please Note: Bill Leavell is a non-member guest and is in no way affiliated with InterNACHI or its members.
We just aquired 6 of these detectors. Can you tell me how to manually discharge one?
Thanks in advance
2 questions staylor5 Electrical Inspections 14 12/18/09 2:32 AM
Escape, Fire & Smoke Alarms badair Interior Inspections 14 1/28/08 7:21 AM
Illinois: Carbon Monoxide Alarm Detector Act rcramer Legislation, Licensing & Legal Issues for Inspectors 2 2/9/07 7:52 AM
NY State Smoke Alarm law bsmith Legislation, Licensing & Legal Issues for Inspectors 15 1/23/06 6:30 AM
