When were detectors first required in all bedrooms?
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
NFPA 72
1993 May vary when your jurisdiction followed it. http://www.nachi.org/forum/showthrea...uired+bedrooms InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Just so you know. Smokes are not covered in the electrical code (NEC - NFPA70).
Here is a interesting SNIGLET from a IAEI article...hope they dont SUE me...
Here is the full post: http://www.iaei.org/subscriber/magaz...b_johnston.htm Provisions for Smoke Alarms The Building Codes generally require rules for fire protection systems and smoke detectors. Building codes will reference NFPA 72 in addition to the specific requirements of the applicable building code. The IRC is no exception. Although smoke alarms and detectors are not a requirement in the electrical provisions of the IRC, the requirements for smoke detectors can be found in Section R317 of the IRC. This section includes the rules for placement, listing requirements, alterations and repairs, and the required power source. Basically this section requires the equipment to be listed and installed in accordance with R317 and the household fire warning equipment provisions of NFPA 72. Smoke detectors are required in each sleeping room, outside of each sleeping room, and in each additional story including basements and cellars but not crawl spaces. Where more than one smoke detector is installed to meet these requirements, all smoke detectors within the dwelling unit require an interlock or interconnection in a suitable manner that upon activation of one, all alarms will be activated. The wiring for these smoke detectors/alarms must follow the applicable provisions of Part VIII (Electrical) of the IRC. Smoke alarm equipment installed in new construction requires a primary source of power supplied by the building wiring and must include a battery backup. Smoke alarms that operate on batteries only are permitted under regulation R317.1.1 for remodels or for buildings that do not have commercial power supplied to them. It is important to consult the local authorities relative to any smoke alarm requirements that may also apply. Paul W. Abernathy |
| 2 questions | staylor5 | Electrical Inspections | 14 | 12/18/09 2:32 AM |
| Escape, Fire & Smoke Alarms | badair | Interior Inspections | 14 | 1/28/08 7:21 AM |
| Stand-alone Smoke detectors (posted by Pamela Bloom) | AskNACHI.org | AskNACHI.org Inspection Questions Forum | 1 | 7/10/07 2:11 AM |
| smoke detectors in bedrooms | bgraham | Electrical Inspections | 12 | 6/28/06 9:12 AM |
