Old 4/24/07, 7:24 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Solid conductor aluminum
I have seen tons of "stranded" #6 aluminum for ranges etc, but I have never seen solid conductor #6 before----in this case to the range. How would you report on this----2003 house.
Old 4/24/07, 7:43 PM
Marc D. Shunk's Avatar
Banned
Default Re: Solid conductor aluminum
Why do you feel the need to report a legal installation?
Old 4/24/07, 7:56 PM
cbuell's Avatar
Marc, at what date between 1975 and now would you consider solid conductor aluminum wiring ok?
Old 4/24/07, 8:31 PM
Banned
Depends on the alloy number. That could be any date. In this particular gauge, I'd never worry about it, no matter what alloy number or what year vintage.
Old 4/24/07, 8:57 PM
Unmoderated Guest
I'd be very curious to see what it says on the sheath of a 2003 vintage cable with a "solid" #6AL inside.
I wouldn't think such a thing existed.
Old 4/24/07, 11:38 PM
I'm with Petey, never seen any cable with solid (anything) above #10, only bare solid 8, 6 and 4 for grounding and that was copper.
Old 4/25/07, 12:43 AM
cbuell's Avatar
Strange stuff---here is a picture of the ground and neutral
Old 4/25/07, 7:03 AM
Unmoderated Guest
Wow! That looks like solid conductor SER cable.
Strange to say the least.
Old 4/28/07, 11:40 AM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Charles
Would you be able to get back to take more pictures and get a number off of the cable these conductors are installed in?
Old 4/28/07, 12:53 PM
The funny thing is I don't see anything prohibiting #8 solid and larger in a cable. You can't pull that in a raceway tho. The only raceway exception is the GEC
Old 4/28/07, 5:02 PM
Roy D. Cooke, Sr's Avatar
I believe you can get solid single conductor Pyrotenax up too 500 mcm
I did a inspected a home with I think it was #2 solid pyro service a few years ago .
I will try and find the pictures .
I put in a lot back about 1960 and we had many sizes 2/0 was very common.
Roy Cooke
Old 4/28/07, 9:08 PM
Does this help?
http://www.harger.com/catalog2004/1_1_2.pdf
Old 4/28/07, 9:53 PM
MI cable in a house? Amazing.
Old 4/28/07, 10:08 PM
The main distributor for Canada is in Trenton and I figured the home owner could have worked there many years ago .
Added Below
The house was knob and tube and had vermulite for insulation so I expect it was from the 1950 +or-
Found the pictures send me email and I will send them back.
Do not know how to post here
Roy Cooke
Old 4/29/07, 11:56 AM
Harold E. Miller's Avatar
Harold E. Miller Harold E. Miller is offline
Charles,
I don't see anything to write up considering the facts you provided. It has anti oxidant at the connections (at least appears to). If it appeared to be a part of the original install as approved by L&I, then I would not personally have a concern.
Does the panel have an L&I "cover" and/ or "final" tag?
Solid Aluminum Wiring carolinainspector Electrical Inspections 7 6/19/06 5:06 PM
