Old 8/24/07, 11:40 PM
whandley's Avatar
whandley whandley is offline
Please Note: whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Spa tub motor bonding?
Ok, I've called out the last two spa tubs I've inspected for not having the proper cold water bonding in place. Each has had a metal motor casing with an "Empty" bonding clamp and or lug clearly visible on the motor. The agent informs me today that an independent licensed electrical contractor inspected and determined that the motors were of a sealed design and did not require bonding.
I'm totally confused, I thought any and all metal within 5' of a electrically supplied pool, spa, spa tub, etc. had to be bonded.
Any thoughts?
Old 8/24/07, 11:47 PM
Jeffrey R. Pope's Avatar
Default Re: Spa tub motor bonding?
If the motor is double insulated, it need not be bonded.
When I see an empty bonding lug, I call it out (assuming the supply piping is metallic), and let the sparky determine if the motor is double insulated.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/24/07, 11:56 PM
whandley's Avatar
Thanks Jeff,
Each of these structures has had copper fresh water plumbing.
Just for the sake of asking, why does the OEM equip any motor that doesn't require bonding, with a bonding lug?
Old 8/25/07, 12:01 AM
Good question, but I don't know the answer
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 8/25/07, 1:07 AM
Brian E. Kelly's Avatar
Was the spa tub piping metal or plastic?
Old 8/25/07, 1:43 AM
whandley's Avatar
Plastic, I haven't seen any metal on bathroom spa tubs for many years. The supply plumbing to the faucets was copper.
Old 8/25/07, 11:59 AM
That was my first thought as well. I'll look forward to seeing the answer from the 'experts'.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 8/25/07, 6:28 PM
whandley's Avatar
Where's Paul, Greg and or Speedy when you need'em?
Old 8/25/07, 6:33 PM
My guess would be mass production...costs more to remove it.
Larry Kage, CMI
231 929 3525
Old 8/25/07, 7:29 PM
Unmoderated Guest
To be honest I have not seen a D-I motor with bond lug.
If the lug is present, I use it.
Old 8/25/07, 8:16 PM
Marc D. Shunk's Avatar
Banned
I second that. I have never seen a double insulated motor with a bond lug on any pool, spa, tub or whatever. I think the spark was blowing smoke.
Old 8/25/07, 8:20 PM
The answer is always supposed to be on the label. U/L has a marking guide for pool/spa motors, just like most equipment and that defines what they have to list there.
Old 8/25/07, 8:34 PM
Banned
The 2005 NEC Handbook reminds us in the commentary to 680.21(B) that attempting to bond a double insulated motor compromises the double insulated properties. Sort of a no-brainer, when you think about it. I can say with reasonable certainty that a a motor with a factory bond lug is not double insulated.
...pump[s] incorporating a system of double insulation are grounded; however, they are not required to be incorporated into the bonding system required by 680.26(B), since the act of bonding compromises the double-insulation system.
Old 8/25/07, 8:39 PM
Always appreciate learning from you guys...
Larry Kage, CMI
231 929 3525
Old 8/25/07, 9:15 PM
What would you bond it to if the plumbing is plastic and there is no other metal parts large enough to require bonding?
