Old 11/21/08, 6:49 PM
Erol Kartal Erol Kartal is offline
Please Note: Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Sparking Receptacle Cover
What may cause the cover to spark when switch is turned on?
Thanks
Old 11/21/08, 6:57 PM
Unmoderated Guest
Default Re: Sparking Receptacle Cover
What exactly is sparking? The plate to the center screw?
Old 11/21/08, 7:01 PM
Yes, Pete. Thanks.
Old 11/21/08, 7:05 PM
Unmoderated Guest
I would pull out the receptacle and check both it and the box for a good ground.
Does this only happen with something plugged in?
What switch are you referring to?
Do any breakers or GFIs trip?
Old 11/21/08, 8:53 PM
Hi Pete,
Sorry, been a long inspection day for a change.
The hard to see white area on the plate is the on -off toggle. When the switch is turned off, a spark can be seen behind the swich. The home is old with no GFCI's and does not trip any breakers. Nothing has to be plugged in order for this to occur. New 200 amp service panel looked good.
Old 11/21/08, 9:02 PM
Bob Elliott's Avatar
Originally Posted by ekartal View Post
Hi Pete,
That sounds normal to me,since it is mechanical ,though if exessive it may need to be changed.
Old 11/21/08, 9:07 PM
James F. McKee's Avatar
Normal for the plate to arc to the center screw ???
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 11/21/08, 9:27 PM
Normal for there to be a small spark, but to the screw may be an optical illusion
Recommend sparky for the spark if unusual, but I bet it is just an old switch that is wearing out.
If you look at a switch with the plate off you can often see a spark from the broken physical contact of the switch.
By nature it will produce an arc.
Old 11/21/08, 9:32 PM
gbeaumont's Avatar
I'd hope not, I bet the receptacle was loose and the live was contacting with the J box.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 11/21/08, 9:53 PM
Unmoderated Guest
I see the switch now.
I'll make a prediction: The switch does not control the receptacle. I bet it controls something else, like a disposal, and the arc spark seen is typical of any switch made or broken under load.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Online Code Check- Reference pabernathy Electrical Inspections 31 11/9/06 3:39 PM
Live weather cover jnicholson Electrical Inspections 13 10/31/06 10:31 PM
