1951 House.
Older Service Drop/Attachment/Meter Updated panel 100 amps. Spliced SEC in panel. Looks to me like they spliced the older 60Amp SEC with 100 amps to accommodate the main breaker. I am calling it out a 60 amps and deferring to an qualified electrical contractor. The only wire I could see was the grounded conductor at the service point. What do you say!! |
| Find an InterNACHI certified Pennsylvania Home Inspector (and anywhere else in North America) |
10-4 Dave...Over~Amped...may cook the little conductor----
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Well now, I'm gettin hungry. SEC: SpicyEdibleConductor ?? |
After you guys finish eating you can throw your garbage in here
What makes me laugh is the garage structure was about 10 feet away. |
That an Ohio (Broadview Hts) Junction Box Dave?----
No!! It is a water proof cover. The agents stated this house had no violations from the local jurisdiction. (Sure right, I need to apply for a city job) This passed inspection. How could he not see the 10 ft. of extension cord on the garage service door. (Probably did not go in garage) |
Ahhh the old extension cord door closer. Fling the door open, rebound closed.
| Minimum br window size? | acatterton | General Inspection Discussion | 4 | 8/3/09 4:27 PM |
| AC breaker size | abolt | Inspecting HVAC Systems | 2 | 6/25/09 6:24 PM |
| Flue Size when size matters? | msylvester | Inspecting HVAC Systems | 14 | 1/20/07 11:29 PM |
| Service wire size to breaker panel | sfalvey | Electrical Inspections | 12 | 10/31/06 4:28 PM |
| Help Determining Reportable Service Size | cbarrows | Electrical Inspections | 8 | 7/19/06 7:12 PM |
