From what I understand about the issues with a double tap are:
1. Multiple wires under 1 lug could work loose. 2. Multiple devices on one breaker could cause overheating and or overload. A local electritian just told me that you can legally splice into the wires running to a breaker rather than double tapping them. Wouldn't this still pose the same concern of multiple devices on one breaker, and therefore require to be fixed. Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
| Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
"Pig-tailing" two conductors to one, is an acceptable way to eliminate a double tapped breaker.
To many outlets on a breaker or circuit can contribute to an overload. A double tap creates the potential for a loose/poor connection, which in turn creates higer resistance and heat build-up. A breaker must be specifically listed to accept more than one conductor. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
| Condensation on outside of my double pane windows | Unregistered-sf | AskNACHI.org Inspection Questions Forum | 12 | 4/29/11 9:50 AM |
| Double lugged breakers? | dbook | Electrical Inspections | 7 | 4/30/08 12:35 AM |
| Double Tap Questions | jkogel | Electrical Inspections | 6 | 6/28/07 9:46 PM |
| Double Tapped Breaker | tjohnson3 | Electrical Inspections | 8 | 4/20/07 9:04 AM |
| Double Taps | rwand1 | Canadian Inspectors | 39 | 3/29/06 7:16 PM |
