What are the two doughnut-looking devices around the main conductors?
This condo had a demand control panel located right next to this sub-panel that helped save money with the radiant heating system. Is this the method for getting power to the demand control panel? Last edited by kshepard; 10/2/08 at 2:40 AM.. |
Current transformers
Is this a Spliceless Splice or a Nutless wirenut?
- Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
I thought duck tape fixed anything. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Ductless duct tape splice.
Current taps (transformers), thanks, Kent |
Metering Toroidal Current Transformers
![]() Traditional, window type current transformers for measuring 50-400HZ currents of 5A to 15000A with secondaries of 0.1A, 1A and 5A (special secondary currents are available). Burden: B 0.1 through 1.8 (2.5VA to 50 VA) with Accuracy class: 0.2 to class 5.0 as per IEC 185 or class 0.3, 0.6 or 1.2 as per ANSI C 57.13. Inside diameters of up to 8.00". Many models are available as U.L. recognized devices. Applications include:
Kenton
Seen this in homes with two meters. I am not certain of the exact reason for the dual meters. These devices are basically an inductive pickup...like a clamp on voltmeter In my cases the wires for the electric heat, and electric hot water were routed through these pickups. The second meter only read this power consumption.....maybe there was a special discount program? Some test pilot? Not sure. |
Aaaahh. Ding! The torroidal transformers don't provide power to the heater control panel. They are the device with which it monitors how much electricity the home is using.
Not a splice, a monitoring device. |
| K&T splice. | egarcia1 | Electrical Inspections | 13 | 2/3/07 7:36 AM |
| White Wire to Breaker and Splice Inside Panel | maitai11 | Electrical Inspections | 31 | 9/6/06 12:09 AM |
| Unprotected splice | mgeddie | Electrical Inspections | 2 | 6/23/06 7:13 PM |
| Yer basic splice for service conductors | kshepard | Electrical Inspections | 10 | 6/5/06 9:22 PM |
| Wire splice in electrical panel | ecox1 | Electrical Inspections | 3 | 3/7/06 9:56 PM |
