Correct me if I am wrong, here.
-House built mid 60's, service entrance panel -Split bus panel -Another set of conductors are attached on lugs beside the SEC lugs, which are then secured further down the panel. At that second securing, it is a double tapped with a smaller wire connecting to the other opposite side. This makes all breakers hot (not fed from upper breaker) and exceeds the 6-throw rule. Right ??? Oh, Stablock panel in hallway. The things we find.! Thanks for all the input |
Linda, I just recently found a panel similar to this one, maybe this will help .
http://www.nachi.org/forum/f19/ive-n...-before-32624/ Looks like in that panel you have to throw every breaker? |
Yes that appears to be the case. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Michael,
Yes. Would have to throw every breaker. Thanks, Linda |
Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Linda .,
You have to defered this to the electrician there is few code volidatons there. Merci,Marc |
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
