Question for you sparkies. Cutler Hammer Split Buss Panel pulls from the main Service Lugs to the 2nd set of Busses terminating with lugs. I thought we couldn't Double tap the mains......There would certainly be more than 6 hand movements to shut off panel. There are also numerous double taps, and we already talked about CH panels allow this...at least some. And multiple neutrals under the same screw. What say ye? Sorry about the bad pic.
"He is no fool who gives what he cannot keep to gain that which he cannot lose." Jim Elliot 1949 Gerald Wilcox Harvey, ND CMIA, RMT www.housecheckhomeinspections.com www.homeinspectorinnorthdakota.com 701.324.4075 Minot, ND Home Inspections Devil's Lake, ND Home Inspections Bismarck, ND Home Inspections Jamestown, ND Home Inspections Home Inspector in North Dakota North Dakota Home Inspection |
That would be an improper modification.
They have defeated the purpose of the split-bus design, and in doing so, violated the "six-throw" rule. This panel needs to be serviced by a qualified electrician, not the "electrician" responsible for the modifications. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with JP. The split bus panel is no longer wired as a split bus, and because there is no main, it is need of correction.
Hypothetically speaking, would this be legal if there were a service disconnect between the panel and the meter, and if the neutrals in the CH panel were floating and separate from the grounds? |
Thanks guys, that's how I wrote it up!
I concur with Mr Pope ( whom I swear moonlights as a very knowledgeable electrician )......
Paul W. Abernathy |
| Rate This Split Bus Panel | rarmstrong1 | Electrical Inspections | 9 | 12/3/06 12:36 PM |
| Split Buss | bwieczorek | Electrical Inspections | 4 | 8/16/06 5:30 PM |
