A previous client called this morning and asked me a question and I wanted inquire to everyone's opinion. This is the emailed received after our phone conversation.
"So here's what we would like to do. We have only 1 x 220V (12 x 2) line to the A/C. The panel is in the opposite end of the house from the A/C and Dryer. I've cut the line to supply the dryer as well. This was only temporary. Now we were wondering if I can legally put a DPDT or DPCO 220V switch in place? "I'm not sure if that is what the switch is that I need" What I would like to achieve is: in the middle position, both units are powered off, in the left position the dryer only is powered on, in the right position the A/C only is powered on. Would this meet code? And if so, any idea where I can get one?" Any thoughts on this situation. I personally recommended to run a new line on the exterior of the home in proper conduit and enter in the home beside the panel. Location is in Ontario, Canada. Any information would be appreciated. Thanks TJ Smith Serving Brockville, Ontario and Surrounding Area TJ@AllOutHomeInspection.com http://www.allouthomeinspection.com "Inspecting your Future" |
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I doubt that dryers in Canada don't require 30 amps, the same as in the US. As such the 12-2 is too small. Dryers in the US also require a 4 wire feeder which the AC line does not have.
IMO: The correct answer is to advise him to hire a qualified, licensed electrician to design and implement an appropriate solution.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
His 12/2 theory is wrong and dangerous besides a dryer needs to be on a dedicated circuit.
As Chuck said: *The correct answer is to advise him to hire a qualified, licensed electrician to design and implement an appropriate solution.* Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
| Excessive Rust on gas line | bhartley | Plumbing Inspections | 3 | 10/3/09 5:11 PM |
| Main Line vs. Supply Line Reporting Details | sshockley | Plumbing Inspections | 2 | 6/14/09 3:07 PM |
| Flex gas line through solid walls???? | rjack1 | Plumbing Inspections | 7 | 4/8/09 11:06 PM |
| Frozen condensate line | dmiller6 | Inspecting HVAC Systems | 7 | 1/18/09 11:25 AM |
| Gas line protection | jlybolt | Exterior Inspections | 2 | 5/30/07 12:18 PM |
