mroach is a non-member guest and is in no way affiliated with InterNACHI or its members.
I see what appears to be speaker wire used to extend the power cable to sprinkler systems from time to time. I usually call it out as a problem. I just wanted to get some feed back on this.
Thanks' Mark |
| Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America) |
I would not call it out as long as the wire is secure and the splice is done in a workman like manner. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Looks like lamp (or 'zip') cord which is adequate for the low voltage service. Not very pretty, but not really hazardous either. However, depending on the distance of the run, voltage drop could be an issue for the sprinkler system. I would probably suggest that the transformer be relocated to a receptacle adjacent to the sprinkler controller.
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Short circuit failures with 12/3 NM-B cable and NM clamp connectors | pabernathy | Electrical Inspections | 10 | 4/17/11 1:43 PM |
| HELP! What do you call a 3 prong male plug with a cord. | gromicko | Electrical Inspections | 5 | 1/9/09 12:33 AM |
| Dwelling and Commercial Electrical Equipment | jtedesco1 | Electrical Inspections | 4 | 1/10/08 6:46 AM |
| Did you KNOW this about NM Cable? | pabernathy | Electrical Inspections | 0 | 12/19/06 8:46 AM |
