Old 6/28/07, 1:46 PM
lfoster's Avatar
lfoster lfoster is offline
Question Sq D 200 amp panel with Cutler Hammer Breaker
Hi. Needed a quick answer, if anyone has one!
Can Cutler Hammer breakers usually be crossed over and installed in Square D panel? As best as I could read the CH label - Type C L 720, T060429, CU/AL SWD
Thanks,
Old 6/28/07, 2:07 PM
Default Re: Sq D 200 amp panel with Cutler Hammer Breaker
This all gets down to how you regard "classified breakers". U/L and C/H say they are OK. SqD doesn't
Classified Breaker Compatibility Chart
Native Document | 5651B63SH04.PDF | (340KB) | relevance:84.99 %
Eaton's Cutler-Hammer Type CL Breakers list for UL approved replacements in Crouse Hinds, GE, ITE, Siemens, Square D Homeline and Murray loadcenters.
http://www.eaton.com/ecm/idcplg?IdcS...=1046632560357
Old 6/28/07, 2:27 PM
Square D's side
http://ecatalog.squared.com/techlib/...00892680139d70
Inspectors split on the issue, most side with U/L listing
Old 6/28/07, 2:37 PM
Scott Schultz Scott Schultz is offline
Please Note: Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
of course square d isn't going to say its ok. That would be like coca-cola saying "you can buy our bottles but you can refill them with pepsi if you want to" Go with the UL recommendation...unbiased.
Old 6/28/07, 4:18 PM
Doesn't the NEC always refer to the manufacturer's instructions, i.e. panel label?
Abraham Lincoln
Old 6/28/07, 5:08 PM
Marc D. Shunk's Avatar
Banned
No, it says to go with listing and labeling instructions. Listing is from UL, and the UL mandates the required labeling language. "Labeling" is not manufacturer's instructions. Labeling is done in compliance with the UL Marking Guide.
Blaine
That is why Eaton C/H will give you a sticker to put in the panel stating the U/L classification of their replacement breaker. It is clear that SqD will not evaluate a C/H breaker in their panel so you have the U/L blessing from their evaluation.
Old 6/28/07, 11:06 PM
lfoster's Avatar
Thanks for all the info.
Great message board !
Linda
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Minimum Size Breaker for Sub Panel rmoewe Electrical Inspections 7 5/21/07 7:24 PM
Service wire size to breaker panel sfalvey Electrical Inspections 12 10/31/06 5:28 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 10:02 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
