Is it acceptable to use Type HOM breakers in a Seimens panel? They appear to fit just fine, but not sure about the conections at the bus bars.
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Here's what I say:
"The [main panel or sub-panel] is equipped with breakers manufactured by a company other than the panel manufacturer. Panel manufactures warn that the use of other types of breakers "voids the warranty, may void the UL listing, and could result in property loss and personal injury." An evaluation of the acceptability of the breakers by a licensed electrician is recommended." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
You have to keep in mind that some panels allow breakers from other companies (usually sister companies under the same corporate umbrella). Read the label if present.
ELEC-classified-breakers
http://www2.sea.siemens.com/Products/Residential-Electrical/Product/Circuit-Breakers/Classified_Circuit_Breakers.htm InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Thanks Joe
Thanks IKage, I feel more educated, but still not sure if the Type HOM are classified for use in the Seimens panel. I guess it is up to AHJ to decide if it is acceptable?
I call it out every time. Read the legend in the panel itself. I states in plain english, that only the same type of breaker can be used. I think of it this way. What if someone inspected the house after you and called it out and then showed that it was written on the panel in plain english. I think I would look dumb, hence I call it out each and every time...
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
If all your question is " can Homeline be installed in a Seimens pane" then my response would be legally no....mechanically yes.....does it make it right ...no.....is it probably safe....yes........will it effect a warranty from square D...well probably not since homeline has a short warranty cycle anyway so the new breaker probably has a longer warranty in itself.
The issues can go alot deeper than just this question.....it goes as deep as understanding the CTL requirements and when they came into effect and will they go away in the 2008 NEC and can you install a CTL rated breaker in a non-CTL rated panel...but alas.......I dont want to bore you with details. No, the Square D breaker should not be installed in the Seimens panel and checking the label should show you that this is not recommended. In fact, square D would throw a FIT ( I know Mr. Pauley of Schneider would ) if you installed a seimens in their panels so I would guess he would agree not to install theirs in another brands panel. Did I confuse you enough...... Paul W. Abernathy |
| Main panel...recommendation ? | dnasser | Electrical Inspections | 6 | 11/22/09 9:55 PM |
| Electric Panel | dmozzillo | Electrical Inspections | 26 | 1/26/09 1:18 PM |
| Cutler Hammer panel with Square D breakers | bhartley | Electrical Inspections | 3 | 11/25/08 9:48 PM |
