Old 2/6/10, 5:37 PM
GLENN R. HELDER GLENN R. HELDER is offline
Default Square D panel
I did an inspection that involved a 200 amp Square D
electric panel and I could not determine if it was
bonded.
No bonding strap or screw
any suggestions?
Glenn
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/6/10, 5:46 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Default Re: Square D panel
Got any pics to show us?
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/6/10, 6:10 PM
Sorry,
No I do not
Old 2/6/10, 6:41 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
I would suggest if you are unsure to recommend a qualified electrical contractor.
When I am in doubt I can count on my friends here, especially Mr. Jeff Pope whom I email or call when I am not sure. I also will call Paul Abernathy.
I am far from an expert but I know when to call someone or differ to a specialist.
Old 2/6/10, 7:46 PM
If there was no strap/screw, it's possible that it was bonded in the meter can.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 2/6/10, 11:18 PM
ecolclasure ecolclasure is offline
carry a multi meter and check for continuity between the neutral buss and the can
Old 2/7/10, 1:37 PM
Jeffrey R. Pope's Avatar
No need to carry a multi-meter. If it's not visible, that's what you report - unable to verify bond.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/7/10, 2:12 PM
Anthony Divello's Avatar
Anthony Divello Anthony Divello is offline
http://captsized.inspectorpages2.com
Home Inspections Rhode Island 401-782-5589
In some cases, the bond is one of the screws holding the bus onto the enclosure. This is often true with the square D panels in my area, and can be verified with a multimeter, if no bare wires are making continuity to the box itself. Can even be tested with simple ac current tester. But this is outside sop scope.
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 9:59 PM
Square D Files Lawsuit to Prevent Counterfeiting jtedesco1 Electrical Inspections 2 5/26/06 6:36 PM
