Old 12/7/12, 7:26 AM
Joshua L. Frederick Joshua L. Frederick is online now
Default Square D split bus modification?
Square D split bus panel with service disconnects at top of panel. What I'm inquiring about is the top left breaker/lower disconnect wires and how the wires appear to just be tucked behing the lower bus bars (visible on left side). This seems unorthodox to me. Usually they're lugged. Is there something behind that I'm missing or can anyone provide any helpful info/recommendations? Thanks in advance.
BTW, there were numerous defective conditions present at this panel and throughout the residence that I'm aware of - only inquiring about the above
square-d-split-bus-modification-img_1284.jpg   square-d-split-bus-modification-img_1285.jpg
Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/7/12, 9:40 AM
William Warner's Avatar
William Warner William Warner is offline
Default Re: Square D split bus modification?
On some split buss panels I've encountered, those conductors are factory spot welded or soldered to the front or back of the "lighting" buss. This may be one of them.
Old 12/7/12, 10:34 AM
Now that you mention it, I do recall a few in the past that were spot welded on the front bus. Thanks for the reply.
Counterfit Square D rgallahorn Electrical Inspections 0 5/27/08 8:18 PM
Square D Files Lawsuit to Prevent Counterfeiting jtedesco1 Electrical Inspections 2 5/26/06 6:36 PM
