Hello,
I'm a new inspector, and I'm in the process of doing some mock inspections. I have found a FP Stablok panel on a new home built in 2009. Is this a major concern? Thanks, Ken |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
WARNING! You are not to remove this panel because it exposes the service area.
The authority having juristiction has not given the OK. And they are dangerous according to most InterNachi Inspectors. Even if they are in new condition they still have the same problems. I do not like that the service portion is on the bottom also. You have a Federal Pacific panel which is legal, but there is a possibility that the circuit breakers may not trip when shorted possibly causing an electrical hazard. Opinions by licensed electricians on this panel varies between safe and unsafe. I recommend you consult a licensed electrician for an opinion and correct if necessary.
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Ken - I will assume you are in Canada as your profile is incomplete.
These are commonplace in Canada. Kevin - can you explain your response? Why would an inspector remove the panel? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
This is Federal Pioneer ! Been around for about 50 years I have used them , been around them , never seen a problem yet . If you are in doubt with any panel (regardless of brand) you should never remove the dead front . Now I have seen a Siemans blown apart . , have seen one with a breaker parted in two pieces . Any panel can be dangerous !
galaxyhomeinspections.com An amateur built the Ark ! Professionals built the Titanic ! |
A new inspector should not remove the dead front cover.
Seasoned and trained in proper electrical schooling with proper safety equipment is OK on some panels and not OK on others. This is part of the training process. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Yes, I'm in Canada. I did not remove the Deadfront, would this be common pratice on this type of panel? It looks like the design of the breakers makes removing the Deadfront a bit of a problem as they extend over the Deadfront.
Thanks for all your help! Ken |
Correct
Still manufactured and approved in Canada .
I expect there is a difference from USA panels . I have a 200 amp in my home no big deal . Roy Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Thanks, Ken |
Are the Canadian FPE's profoundly different than the firestarters that we have here in the US?
I've seen no difference in designed components - same key-holed bus bars, same Stab-lok breakers - but Canadians are still installing these things in new construction. Although they are now Federal Pioneer. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
So I'm guessing that they've changed some elements of the design to fix the problems we have with the equipment from the 60's and 70's. |
I do report size and manfacture of all panels . The answer is NO report ,and do not mention it . I have seen no reason to say any thing. Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Federal pacific here in the US. You have Federal Pioneer. In the US the UL carefully looked at the federal Pacific breakers and there associated problems. After review, they did NOT revoke the UL rating, contrary to what most believe. I report that these panels have been known to fail to open under heavy load and also fail to open when manually turned off. This is really all I can say, as that is the extent of what UL found and what I have experienced. Additionally, the problem was limited to specific sizes of breakers ( size I cannot recall).
| Electrical for Dummies | mcyr | Electrical Inspections | 16 | 6/9/08 9:59 PM |
