Old 5/28/08, 10:20 PM
Al D. Bolt Al D. Bolt is offline
Default Stacked AFCI's
Somewhere on the NACHI site (can't remember where right now) I came across the following comment or statement: "Some AFCI breakers have been known to overheat when stacked, causing premature tripping when outlet(s) are used." Does anyone know any brand names or specifics?
BTW, I am starting to see some AFCI's being separated in the panels.
Thanks.
Old 5/28/08, 10:43 PM
Marc D. Shunk's Avatar
Banned
Default Re: Stacked AFCI's
If you ask any manufacturer, they say it's not a problem. Some electricians have experienced this to be a problem (not life-safety, but a nuisance). I have not personally had this problem nor have I observed it to be a problem. That said, it might be an issue more in panels that are mounted in higher ambient operation environments, such as outdoor panels in the southwest or FL.
Old 5/29/08, 12:32 AM
tdietrich1's Avatar
I have Sqaure-D Homelines, stacked(soon to be more if Marc can get me CAFCI's cheap ), and no problems since installed.
tom
Old 5/29/08, 6:44 AM
David P. Valley's Avatar
I'm not familiar with NEC regs on AFCI stacking in a SE panel, but I do know that AFCIs (due to their intricate circuitry), generate more heat than a standard breaker. When these are placed together, I've seen them register 130 degrees on my laser thermometer. (Granted this was a hot day, but the center breakers were 30 degrees hotter than the regular breakers on either side)
There is a very simple but necessary fix. The AFCIs are interspersed with standard breakers in between. This keeps the temperature down to a more reasonable 10 or so degrees warmer than the standard breakers.
Old 5/29/08, 11:04 AM
Since breakers are calibrated at 40c (104f) I thought I might get some traction with this in the comment phase of the 2008 Ref 210.12 but NFPA basically said any concern about this was unfounded.
Old 5/29/08, 11:09 AM
Michael Larson's Avatar
Not sure what you mean by "calibrated" at 40° C
They are tested at that ambient temp for insulation resistance to moisture and maximum operating temp of parts.
Michael Larson
Hudson, WI
Old 5/29/08, 11:45 AM
That is the ambient temperature that they use on the trip curve charts. Presumably the thermal element will operate differently if it is hotter. I was really hoping NFPA would expand on that a bit in the NOC but they basically just blew off the question.
Old 5/29/08, 12:04 PM
Gotcha, thanks
Michael Larson
Hudson, WI
Old 5/29/08, 12:05 PM
mnahrgang's Avatar
Originally Posted by dvalley
I... When these are placed together, I've seen them register 130 degrees on my laser thermometer. (Granted this was a hot day, but the center breakers were 30 degrees hotter than the regular breakers on either side)...
So... How hot, is too hot? 150, 175, 200, ? Where should we draw the line, and call these (or any other breaker for that matter) out?
Mark Nahrgang
www.HeyMark.info
Old 5/29/08, 11:00 PM
Banned
You might be crossing some sort of line that ought not be crossed if you're asking that question. Your answer, however, is in the NETA testing specs.
Old 5/30/08, 1:06 AM
I just looked in the U/L marking guide to see what they say the 40c means.
"A circuit breaker that is acceptable for use in ambients up to 40c is marked 40c".
Old 6/4/08, 8:44 PM
Stacking is not a problem ( That I am aware of ).....have had stacked AFCI's and GFCI's together for nearly 3 years now ( in excess of 10 stacked ) and no problems.
Paul W. Abernathy
QOD for 1/26/07 - AFCI's jbowman Inspection Question of the Day 43 4/1/09 9:17 AM
NASFM Flashback on AFCI's jtedesco1 Electrical Inspections 0 1/13/08 9:48 AM
Stacked Washer and Dryer Power Source Skip Erwin Electrical Inspections 19 10/8/07 3:19 PM
Questions with regard to GFCI's and AFCI's and how they work/test. dmull1 Electrical Inspections 13 5/17/07 11:13 AM
AFCI's Explained by Mike Holt & Eaton Engineer pabernathy Electrical Inspections 19 2/15/07 12:05 PM
