I've been doing quite a few "new-construction" inspections lately, and have been running into the same problem over and over. Needless to say, some of the builders aren't happy with some of my "findings."
CA has a relatively new energy code, built into its building codes (Title 24), which requires (among other things) that all incandescent light bulbs be placed on dimmer switches. The problem is with the stairway lighting. How can the lighting "legally" be on a dimmer? When the dimmer is turned down, this effectively disables the opposite switch. I have discovered this at least 4 times in the last month. Is there a "reasonable" solution to this? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 8/2/07 at 1:35 PM.. |
I think the intent is thay you use a CFL there.
What's a CFL?
That's what I thought.
Ahhhh but those wonderful CFL's have that wonderful mercury hazard...
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
I think the interpetation of the Title 24 laws need some common sense applied to them. I'm a Title 24 energy plan examiner and the laws can be confusing to the layman. For a good guide to new construction lighting, I use the guide supplied by the UC Davis Lighting Technology Center. Here is the link.
http://cltc.ucdavis.edu/title-24-res...gn-guide-files About fluorscent lights, they need some time to warm up to get the full light energy out of them. For lights that get switched on and off constantly, an incandescent light is better. |
Thanks for the link. I haven't read the pdf yet.
The builder reps believe that cfl's don't provide adequate lighting for the stairway, perhaps for the reasons you suggested - the "warm-up" time. So, what to do? How do we provide adequate and proper stairway lighting with Title 24 in mind? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I actually put switches in my stairway at home that dim from both switches.
But if you can "disable" the opposite switch by turning-down one dimmer, the lighting is improper.
I didn't know they made those. Pricey little buggars.
I just replaced single dimmer with a 3 way dimmer (Leviton) for my dining room. I didn't know they had such a critter either. It can be safely and legally wired for single pole or 3 way. Cost me around $15. It has a rocker switch and a slide dimmer.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Several manufacturers are now making LED stairway lights.
I think most of the resistance to CFLs is misplaced. Perhaps if you are talking about outside stairs in the mountains where it really gets cold I could see "warm up" being a problem but I have them all over my house and they start just fine down to the high 40s.
I was slow to jump on the CFL bandwagon but that is pretty much all I buy these days. A 100w equivilent bulb will certainly get you 70-80% within a second of turning on, even outside at 40f. That is better than the typical 60w builder grade luminaire you see on steps. |
| Light switch where entering a room. | mgault | Electrical Inspections | 19 | 11/17/07 8:00 AM |
| Holiday Lighting question | pbolliger | Electrical Inspections | 17 | 12/30/06 8:01 PM |
| Wiring of residential lighting fixtures | jtedesco1 | Electrical Inspections | 0 | 12/19/06 8:14 AM |
| Emergency Lighting (commercial) | mcyr | Electrical Inspections | 24 | 6/10/06 10:06 AM |
| Attic Stairway Lighting | jhagarty | Electrical Inspections | 0 | 6/3/06 1:30 PM |
