Old 12/13/07, 2:54 PM
Default State of Pennsylvania 2005 NEC
The Pennsylvania Department of Labor and Industry recently issued an Advisory on certain electrical requirements in the Uniform Construction Code (UCC). The UCC was enacted January 1, 2007 and is based on the 2006 ICC Codes including, the ICC Electrical Code 2006, International Building Code 2006, which both utilize the 2005 National Electric Code and the International Residential Code 2006, which contains electrical provisions based on the 2005 National Electric Code.
The 2005 National Electric Code and the International Residential Code 2006 contain two provisions that have effective dates of January 1, 2008. The requirements are NEC Section 410.73 (G) and IRC Section E3802.12. NEC Section 410.73 (G) requires a disconnecting means for fluorescent luminaires (fixtures) that utilize double-ended lamps and contain ballast(s) that can be serviced in place or ballasted luminaires that are supplied from multiwire branch circuits and contain ballast(s) that can be serviced in place, which are installed in other than dwellings and associated accessory structures.
The other requirement is Section E3802.12 of the IRC, which requires all branch circuits that supply 120-volt, single-phase, 15- and 20-ampere outlets installed in bedrooms to be protected by a combination type arc-fault circuit interrupter. The requirements will be imposed on all electrical work for which an application for a UCC building permit is made on or after January 1, 2008.
Old 12/13/07, 5:41 PM
tdietrich1's Avatar
Default Re: State of Pennsylvania 2005 NEC
And the advisory said?
tom
Old 12/13/07, 6:34 PM
jmichalski's Avatar
jmichalski jmichalski is offline
Please Note: jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Tom, I think the advisory was simply a general reminder that these two provisions have an enactment date of 1/1/08.
Old 12/13/07, 10:53 PM
tdietrich1's Avatar
Oh, I would say dur... but this was true since the 2005 was adopted in 05.
I thought there was a stay on enforcement, since I have not seen 'combination-type' afci's readily available yet.
tom
Old 12/13/07, 11:12 PM
Look here
Old 12/13/07, 11:35 PM
More Information for:
Arc-fault Circuit Interrupters, Combination Type
Old 12/14/07, 12:46 AM
tdietrich1's Avatar
Readily available?
Home Depot, Lowes, or our local supply shops? I'll have to look harder.
tom
Old 12/14/07, 6:13 AM
Ask Here or Call UL
Old 12/16/07, 11:12 AM
tdietrich1's Avatar
I guess I'll be picking these up.
http://tnblnx3.tnb.com/emAlbum/album..._Luminaire.pdf
tom
Stupid ASHI legislatin in Washington DEAD. gromicko Legislation, Licensing & Legal Issues for Inspectors 20 1/29/08 9:05 AM
CMI imposter? jbraun Certified Master Inspector (CMI) Discussion 118 11/26/07 4:55 PM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 126 4/27/07 11:05 AM
NACHI has hired a lobbyist to go to New Hampshire today (Wed). gromicko Legislation, Licensing & Legal Issues for Inspectors 21 8/17/06 7:37 PM
