Old 10/27/08, 8:04 PM
Stewart Mussolum Stewart Mussolum is offline
Default Step Down Transformer
Inspected a commercial building today with four step down transformers. Three of the four were operating at between 80 and 85 deg f. The fourth was at 168 f. Two of the four are 25 kva @ 575 down to 240/120vac. the others are 15kva @ 575 down to 240/120vac.They are all located in the same mechanical room. I know they are all rated @80deg celcius and the 168 deg f falls within that but can anyone offer an expanation as to why the one is running at a higher temperature than the others. Is it possible that the load being drawn on the higher temp transformer is higher and causing the higher temperature reading.
Old 10/27/08, 9:14 PM
Gary T. Heller's Avatar
Default Re: Step Down Transformer
That transformer is probably just drawing more current than the other two. The higher the load, the higher the temp.
Old 10/27/08, 9:17 PM
Marc D. Shunk's Avatar
Banned
What he said. These things can get pretty freaking hot when they're loaded closer to their maximum rated capacity. Some are even rated to be overloaded for short periods of time. There can be some serious heat rolling out of them puppies sometimes and still be completely within spec.
Old 10/27/08, 10:22 PM
Thanks guys
Old 10/28/08, 2:21 PM
Remember also that the nameplate temperature rating is the allowable temperature RISE over a standard ambient (usually 40 deg C). As mentioned before that can result in very hot running temps for a heavily-loaded transformer.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 11/1/08, 8:14 PM
rromoser's Avatar
rromoser rromoser is offline
Does the transformer in question have the proper clearances to walls to allow for ventilation? Typically 6 inches is minimum wall clearance. Also a very dusty/dirty transformer runs hotter.
Transformer humming noise mnicholet Electrical Inspections 13 11/25/08 4:05 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Step crack leading to further cracks gmendes Structural Inspections 5 6/21/07 10:40 AM
Step cracks in stucco on block home dbucknavich Structural Inspections 1 5/19/06 7:53 PM
