Inspected about an 80-year old house today. It had some electrical issues. The oddest one was that I could not get the hall light to come on initially, but later I noticed that it was on dimly. Towards the end of the inspection, I was checking the oven which had been on for a while. It was just barely warm. I turned the knob up and out of the corner of my eye, I noticed it get brighter in the hallway. After playing around with the oven knob for a couple of minutes, I realized the hall light came on dimly when I turned the oven knob on. I could turn the hall light on brightly by turning the knob to "Broil".
I'm not necessarily asking for an explanation of this. I just wanted to share this with ya'll. Mike Morgan Central Texas Home Inspections mike@centraltexashomeinspections.com www.centraltexashomeinspections.com |
Is there a Problem with that? Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Sounds Like a neutral is loose in the panel .
Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
that is a good one!
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Very nice...
IMHO: Definiately defer to an electrician. tom |
How would a floating neutral create this condition?
Simple terms:
Voltage is the measure of potential between two points. This case what is called a 'hot' and a 'neutral'. For case of argument we can assume a good path for electricity back to the source will mean that a neutral is zero volts, since no 'back-pressure' is created. When you loose a neutral in the panel going back to the service, you loose that great path back to the pole, and now electricity must 'return' via another path, often the grounding rod or grounded water piping. Since there is much resistance, this creates a sort of back-pressure. So very little electricity(amps) can flow. So lights(120 volt) dim, and electric toasters[120v] don't heat up. I tried to keep it simple for typing reasons, if something doesn't make sense, feel free to ask, but it comes down to this, if the return path is broken, then no flow of electricity. However if there is a grounding path(ground rods,etc), electricity will continue to flow very slowly, since the earth is a path back to the electric source. You can verify this on different levels. As a HI, you can visually inspect the service conductors, see if the cables are in good condition, good crimps at the POA. Look inside the panel, do all wires look properly terminated, and uncorroded? As an electrician, there are other opptions, amp meter on the grounding electrode conductor, votages accross bars, etc. Once again IMHO: Defer to an electrician. tom |
Tony, Tony.....
The service is 240 volts. When the oven did not get very hot, I thought it may only be getting 120 volts.
" I turned the knob up and out of the corner of my eye, I noticed it get brighter "
"When the oven did not get very hot, I thought it may only be getting 120 volts" This is a textbook case of an open hot leg. Last edited by brian winkle; 11/9/06 at 10:27 AM.. |
Michael Martin is a non-member guest and is in no way affiliated with InterNACHI or its members.
But a simple open hot leg doesn't explain the effect on a hall light.
What if the oven and hall light were on the same circuit, the light downstream from the oven and the light had the switch on the neutral conductor instead of the hot.
| Is inadequate roof or attic ventilation a defect? | gliebig | Exterior Inspections | 85 | 1/16/08 7:56 PM |
| Can you find the defect.... | dmacy | Plumbing Inspections | 7 | 3/21/07 6:57 PM |
| A box cover can fall off and become a defect | jtedesco1 | Electrical Inspections | 5 | 4/3/06 1:42 PM |
| Homeowner special....defect or just informational? | tneumann | Plumbing Inspections | 7 | 2/9/06 3:32 AM |
