Old 1/21/14, 5:34 PM
mtyson mtyson is offline
Default Stumped on discoloration
Today's inspection circa 2001. 200 amp Siemens 42 circuit panel with 35 of the available circuits being utilized. All 8 of the 2-pole 240v breakers were stacked left and the 19 single pole 120v breakers on the right side. Unable to determine connection to earthen ground connection as the grounding electrode was not exposed (covered over with poured concrete side walk servicing garage man door.
This is a back to back service (first point of disconnect) located in the garage with neutrals and grounds sharing the same bars. Upon removing the dead front cover observed that all of the bare ground wires were blackened, but the neutrals and load carrying branch circuit wiring had not been affected. Opened GFCI outlets within the garage and no discoloration was observed at these devices.
While realizing that load balancing is not really that big of a deal on a residential service it is not common to see all of the single pole and 2-pole breakers stacked?
Can not verify earthen ground? Home is located on brackish waterway, irrigation water provided by public utility. No other blackening of copper wire observed at various other devices within the home and no discoloration of other wiring within the panel kinda rules out a type of environmental contaminate? I am stumped
stumped-discoloration-william-thomas-074.jpg   stumped-discoloration-william-thomas-075.jpg
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/21/14, 6:10 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Stumped on discoloration
It is typical to see that where the cable has gotten wet.
Old 1/21/14, 6:28 PM
Are you thinking that perhaps the home was not dried in before electric rough; that because the current carrying conductors would not have been stripped for landing at this point and therefore would not have be affected by exposure to moisture
Mark S. Tyson
Member N.A.C.H.I.
IAC2 certified
Old 1/21/14, 6:33 PM
Sean Fogarty's Avatar
Isnt it humid if FL. Not being a smart azz but just sayin. Some darkening of bare copper wiring is common IMO in areas that are suject to outdoor envirometal conditions. A open garage would be no different.
Fogarty Inspection Services Group of Palm Bay FL
Florida Licensed Home Inspector #8351
Certified Master Inspector
Home inspections, Commercial Inspections, Thermal Imaging, Wind Mitigation and Insurance Inspections for Palm Bay, Melbourne, Cocoa, Titusville, Vero Beach and all the surrounding areas.
321-506-5125
[email protected]
www.homeinspectorpalmbay.com
Old 1/21/14, 6:52 PM
Roy D. Cooke, Sr's Avatar
also looks like white wire used on a 240 volt circuit should be painted or taped, black
......If you do not search for more ,
...............You will never find it.
Old 1/21/14, 7:37 PM
Originally Posted by btoye View Post
Underground service?
Yes underground service
Mark S. Tyson
Member N.A.C.H.I.
IAC2 certified
Old 1/21/14, 7:44 PM
Roy,
Your correct, but until March 1st 2002 Building Officials had description as to when they adopted new code articles.As this prorpetty was permitted before FBC 2002 am unable to confirm
Mark S. Tyson
Member N.A.C.H.I.
IAC2 certified
Gray irregular discoloration pattern Unregistered AskNACHI.org Inspection Questions Forum 5 5/29/12 8:52 PM
Discoloration in evaporator lfoster Inspecting HVAC Systems 3 7/13/08 10:57 PM
Wooden shingle siding discoloration wdecker Exterior Inspections 4 3/26/07 11:07 AM
Ceiling discoloration from joists? dtaylor General Inspection Discussion 4 8/3/06 12:27 AM
Discoloration was caused by a lightning strike! jtedesco1 Electrical Inspections 0 1/29/06 5:51 PM
