It appeared that these two breakers were installed for the sales office in the garage as this was a former Ryland model home. I could not tell if they were still being used. Besides overloading the space is there some other violation here? There was no breaker id.
Also a Siemens main was used with a Square D sub. Does that fly or does it just depend?
Yikes! That is garbage.
Yes…amazing for 550k and get electrical like this. -X
Start over
Those two on the bottom look like 3-phase commercial breakers which get screwed onto the bus. Looks like they used them as line side terminals. It’s a jury-rigged mess.
Needs a new panel with adequate capacity for the branch circuits installed.
Wrong type of breakers
Too mane breakers for the panel
Failure to separate grounded and equipment ground conductors
How well did the dead-front fit?
Those are 3 pole contactors not circuit breakers.
Here’s a 40 amp version:
http://www.kentstore.com/images/products/detail/eaton_C25.16.jpg
Quite surprised that it fit well.
Thanks. Did not recognize these. Must have been used for the sales office.
Thanks for the analysis.
It looks like an “electrician” bet his buddy that he could get it all in the box.
Hope you waited on the correct answer from Mr Meier
Hmmm…ironically…
World English Dictionary
**contactor **(kɒnˈtæktə) http://static.sfdict.com/dictstatic/g/d/dictionary_questionbutton_default.gif — ***n ***a type of switch for repeatedly opening and closing an electric circuit. Its operation can be mechanical, electromagnetic, or pneumatic
So how many of you think this applies:
[FONT=Times-Bold][size=2]312.7 Space in Enclosures.
[/size][/FONT][FONT=Times-Roman][size=2]Cabinets and cutout boxes[/size][/FONT]
[size=2][FONT=Times-Roman]shall have sufficient space to accommodate all conductors
installed in them without crowding.
[/size][/FONT][FONT=Times-Bold][size=2]312.8 Switch and Overcurrent Device Enclosures with[/size][/FONT]
**[size=2][FONT=Times-Bold]Splices, Taps, and Feed-Through Conductors. **
[/size][/FONT][FONT=Times-Roman][size=2]The wiring [/size][/FONT][size=2][FONT=Times-Roman]space of enclosures for switches or overcurrent devicesshall be permitted for conductors feeding through, spliced,
or tapping off to other enclosures, switches, or overcurrent
devices where all of the following conditions are met:
(1) The total of all conductors installed at any cross section
of the wiring space does not exceed 40 percent of the
cross-sectional area of that space.
(2) The total area of all conductors, splices, and taps installed
at any cross section of the wiring space does not
exceed 75 percent of the cross-sectional area of that
space.
(3) A warning label is applied to the enclosure that identifies
the closest disconnecting means for any feedthrough conductors.
[/size][/FONT]
