Sonny C. Shipler is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm new to This trade (HVAC/R TECH). I need to clarify an arguement I had today with a friend (non electrician). Do Sub panel boxes need to to be bonded to the service box via metal conduit? I said yes. I looked it up in the NEC (1999 BOOK)
QUOTE FROM THE BOOK "To remove dangerous voltage,we must clear the ground-fault by quickly opening the circuit overcurrent protection device. To open the circuitovercurrent protectiondevice,the saftey grounding path must have sufficient low impedance. This is accomplished by bonding metal parts to each other then bonding metal parts to the grounded (neutral)conductor at one location in accordance with sec 250-142" Then he asked about plastic conduit that electricians are using. Well now I'm LOST AGAIN. Plus I have an elecrtical book for wiring houses from Menards and they do not talk about bonding sub panels (Black &Decker complete guide to home wiring). So am I right about bonding sub panels with metal conduit, and what about plastic conduit? I appreiciate all your help |
the Ground in a multi conductor cable or via the metal pipe. Please do not hesitate to ask any questions others also learn from your questions . Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
ROY is 100% correct......
When using EMT which I will take as such in your example, you are allowed to use the conduit itself as the Equipment Grounding Conductor ( which I happen to wish they would rename it as Equipment Bonding Conductor...but alas I don't sit on the CODE panel....YET anyway.... SO bacically you have to ensure the BONDING remains in place when using that conduit to ensure a low impedence path for a fault...when using non- metalic rigid conduit ( PVC-40 or 80 ) you will have to ensure a EGC is run ( EGC -ie: Equipment Grounding(BONDING) Conductor from the panel through that conduit to the device.... If using Romex or ( Non-Metalic Sheath Cable ) the EGC will be within the cable itself ( thus in older applications with NO EGC thus ungrounded ) and that is your bonding conductor. I think THIS is where people get confused with the NEC.......the NEC itself does not seem to know when something is a BONDING conductor and when it is a GROUNDING conductor......yet they TRY to define it and they do it WRONG...yep I said it...the NEC Code Panel is doing it WRONG in my opinion but again who am I.....country boy in VA... Anyway I hope this assisted you Sonny.... Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year Last edited by pabernathy; 1/27/07 at 5:31 PM.. |
DANG......ROY I mean...lol.....man I can't get ANY slack...lol
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
| Panel Inspection Safety | roconnor | Electrical Inspections | 10 | 9/24/06 10:02 PM |
