Old 10/5/10, 11:43 PM
Justin Roberts's Avatar
Justin Roberts Justin Roberts is offline
Default Sub Panel
This was a sub panel for a guest house that was above a garage.
Justin Roberts
Roberts Property Inspections
PO Box 1972
Big Bear City, CA 92314
(909) 618-4697
BigBearHomeInspections.com
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/5/10, 11:50 PM
Default Re: Sub Panel
Fused neutral??
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 10/5/10, 11:52 PM
Originally Posted by jwicklander View Post
Fused neutral??
Not sure. what do you think?
Justin Roberts
PO Box 1972
(909) 618-4697
Jeffrey R. Pope's Avatar
Yep, fused neutral. No good.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/5/10, 11:54 PM
What makes it "fused neutral"
Justin Roberts
PO Box 1972
(909) 618-4697
Old 10/6/10, 12:00 AM
Well, the white wire (neutral/grounded conductor) is connected to a fuse.
Back in the 20's and early 30's, fused neutrals were relatively common. Codes changed after it was discovered that a fused neutral can present a serious safety hazard.
When the fuse on the neutral blows, it gives the false impression that the circuit is not energized, when in fact, it's just waiting to bite you.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/6/10, 12:03 AM
Thanks Jeff
I will keep that in mind
Justin Roberts
PO Box 1972
(909) 618-4697
Old 10/6/10, 12:04 AM
Christopher Currins's Avatar
Was some of the wiring knob and tube?
Christopher Currins
Certified, Licensed
Old 10/6/10, 12:05 AM
No i dont believe so
Justin Roberts
PO Box 1972
(909) 618-4697
Old 10/6/10, 7:08 AM
Robert Meier's Avatar
Not to mention an open neutral on a MWBC will allow the voltage to divide on the two circuits based on the resistance of those circuits. Might be saying good bye to a lot of sensitive electronic equipment if that neutral fuse blows.
Old 10/6/10, 3:08 PM
Roy D. Cooke, Sr's Avatar
Exactly and trying to explain this to an amateur electrician that twin taps on Neutrals could lead to a lot more damage then twin taps on a breaker is hard .
That is also a 3 phase disconect not allowed in a Home system.
Also twin tapps .
It is just bad and needs immediate repair by a qualified person.
Roy
Old 10/6/10, 3:15 PM
Also twin tapps .
Roy
To the best of my knowledge, most 3 phase disconnects can be used for single phase loads.
Old 10/6/10, 11:51 PM
Could be a Canadian thing. You are right...you would just have a set of lugs not being used.
Jeff
Jeff Wicklander
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 9:59 PM
Panel Inspection Safety roconnor Electrical Inspections 10 9/24/06 9:02 PM
