Old 4/11/13, 6:05 PM
Christopher Currins, CMI's Avatar
Christopher Currins, CMI Christopher Currins, CMI is offline
Default Sub-panel
How do like this one?
Pic 2 is the feed to sub.
CBC HOME INSPECTIONS
Christopher Currins
Professional Home Inspector In Edwardsville, Glen Carbon, Godfrey, Maryville,
Fairview Heights, O'Fallon and surrounding areas of S
outhern Illinois
We Make It Safer
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/11/13, 7:10 PM
Bob Elliott's Avatar
Default Re: Sub-panel
Looks like the lamp cord you guys use is missing a bushing at the bottom of that sub as well.
Old 4/11/13, 7:30 PM
Good eye. That's at the bottom of the list for this one. Below double tapped feeders at main lugs, double tapped aluminum/copper at ground bar, 2-wire feed with ground at sub, neutral/grounds bonded at sub, double tapped breakers at sub, etc. etc.
Christopher Currins
outhern Illinois
We Make It Safer
Old 4/11/13, 8:42 PM
So was there anything wrong ?
Nothing a little conduit can't fix.
Christopher Currins
outhern Illinois
We Make It Safer
Evaluating your home's wiring system mcyr Electrical Inspections 2 8/13/13 8:00 PM
Main Panel or not? tgreenwald Miscellaneous Discussion for Inspectors 0 12/20/12 12:20 AM
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 7:28 PM
Need help understanding panel dokeefe Electrical Inspections 7 10/27/08 9:23 AM
Subpanel wired as main panel. jlybolt Electrical Inspections 15 5/23/07 4:10 PM
